Old 02-14-2011, 02:28 AM   #1
Btc10
Key cylinder on drivers side door
My key cylinder was working just fine until I put my new weatherstripping in and it won't lock when I shut the door all the way but, when the door is shut half the way it will lock. Can somebody help me find a way to get the door to lock all the way?
Btc10 is offline   Reply With Quote
Old 02-14-2011, 06:01 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: Key cylinder on drivers side door
Sounds like the weather stripping isnt allowing the door lock to close all the way to me.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-15-2011, 01:56 PM   #3
MrDude_1
the weatherstripping is putting too much pressure on the lock mechanism to let it move...
you can try lubricating the lock, latch, and linkage, and see if thats enough to make it move..
MrDude_1 is offline   Reply With Quote
Old 02-15-2011, 05:10 PM   #4
Btc10
I did all of that and it worked and I put a shim in the striker and moved it forward a little bit and put some pressure on the door and it locked. Thanks for yall's info.
Old 02-15-2011, 06:12 PM   #5
AceX
>130dB Moderator
AceX's Avatar
Glad to hear it turned out well.
Living Life @ 130dB
RIP El Jay
