Old 02-14-2011, 02:33 AM   #1
Btc10
Key cylinder on drivers side door
My key cylinder was working just fine until I put my new weatherstripping in and it won't lock when I shut the door all the way but, when the door is shut half the way it will lock. Can somebody help me find a way to get the door to lock all the way?
Btc10 is offline   Reply With Quote
Old 02-14-2011, 06:33 AM   #2
JimKshortstep4x4
Re: Key cylinder on drivers side door
Try pushing in on the door when you are trying to turn the key.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-14-2011, 10:28 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I think Jim has the answer. It is because there is too much pressure on the door latch. If it is hard to lock you can move the striker plate on the door jamb out a little. Just be sure to mark around it with a fine felt tip marker before you loosen the bolts so you know where it was originally. I would only move it out about 1/16th of an inch to start with. Make sure it doesn't drop down any....
LockDoc
Leon
Old 02-14-2011, 10:34 AM   #4
steelscout
Words under my name
steelscout's Avatar
Have you tried poking a few needle sized holes into it? might release some of the air caught up in it.
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 02-14-2011, 03:25 PM   #5
Btc10
Okay I will try that and I will let you know if it works. No I haven't tried the needles.
Old 02-15-2011, 05:12 PM   #6
Btc10
I put a shim in the striker like yall told me and moved the striker forward a little bit and I put some pressure on the door and the door locked. Thank yall for the info.
Old 02-15-2011, 05:53 PM   #7
LockDoc
LockDoc's Avatar
Actually, by move it out I meant to slide it towards the outside of the truck so the door doesn't close so tight but if that worked all is well...
LockDoc
Leon
