Old 02-14-2011, 11:20 AM   #1
7T2
Active Member
7T2's Avatar
Where to find clip style steel wheels?
Anybody have any sources for new steel wheels with the clips on them that hold 55-57 style dog-dish hubcaps? Seems as though Wheel Vintiques just started making them, but not in the truck bolt pattern.
How hard would it be to swap from 73-87 brake discs to ones with a 5 on 4.75 bolt pattern?
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 02-14-2011, 05:58 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: Where to find clip style steel wheels?
I haven't seen anyone making an exact replica yet. I saw the same wheels you did by V.W.W.
Might want to check in the 73-87 area or the suspension forum to see what it would take to switch to a different bolt pattern on that piece.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-14-2011, 08:38 PM   #3
Dan Bowles
AD Addict
There was a later model Camaro that had heavy duty brakes on it. The discs will fit on the 73-87 spindles with some changes to the inner and outer bearings. You may have to do some research. I looked at doing it for the cradle that is swapped into my son's 49 1 ton panel but I decided to go with a cross member change.
Dan Bowles is offline   Reply With Quote
Old 02-14-2011, 10:35 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
now this answer is out of left field .........
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-15-2011, 12:27 AM   #5
7T2
Active Member
7T2's Avatar
Not really...I have a 73-87 front suspension setup on my 57, and if I can just swap the discs out for ones with a different bolt pattern I might go that route. I would just do adapters, but I don't think I have the room to add a 1 inch adapter in unless they can make the wheels with custom offsets.
1957 GMC Ambulance
1962 Belair Wagon
Old 02-20-2011, 12:04 PM   #6
7T2
Active Member
7T2's Avatar
Question: If I am searching for a set of these wheels:
..that will mount those hubcaps properly, what years were the clip-style wheels used? I think 55-57 wheels would work, but after that I'm not sure when GM switched to the hubcaps that were held on differently. Just trying to figure out what to search for...would 58-59 steel wheels be the same? 1960-on? I don't want two-piece wheels with the retaining ring.
1957 GMC Ambulance
1962 Belair Wagon
Old 02-20-2011, 04:11 PM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I believe that is the 1LE brakes. There also my be some caprice/impala rotors that will work. I looked at them while I was doing a tall spindle conversion on a chevelle. Seems like it was non ss impalas 92 or 3. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
