02-14-2011, 01:20 PM | #1 |
Coys C5 / Boss 338 wheel question
I see a lot of trucks out there with Coys and Boss wheels, but I know .. there's a reason for that. They look really good on our year trucks. I like Intro Pentia too. I am just considering it right now, my rallys will need to do for a while.
I just have a question. My truck has the 73-87 cross member swap. Would I have the hub fit problems on the front rotors? Are the 71-72 different (OD of the hub) than 73-87 style? Would the front backspacing need to change, ex. tie rod differences, or anything? The PO has the factory spring with one turn cut out. I was thinking maybe ECE 2.5 drop spindles but I'm afraid that'd be too low with the big block. Your thoughts? Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-14-2011, 01:41 PM | #2 |
///Relaxed Atmosphere
Re: Coys C5 / Boss 338 wheel question
IMO-reason for that is the price heres mine with intro pentias, very easy to clean and polish
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab Last edited by original-71; 02-14-2011 at 01:44 PM. |
02-14-2011, 01:48 PM | #3 |
Your truck looks incredible .. Wow.
Mine is a stepside, I'm not sure I could handle that much tire though. Beautiful truck. .. Thank you for the pics.
02-14-2011, 01:51 PM | #4 |
thank you buddy any help i can be ill be glad to help, do you got pics of yours?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
02-14-2011, 01:54 PM | #5 |
RAT1968 '68 Cab/'71 Parts
I can't directly answer your question. But maybe I can add something.
When I ordered my Boss 338's, I made a silly assumption. I Ass-umed that the backspacing on the 20's (5 x 5 lug pattern) was standard. That may be true. I ordered 20 x 8.5 for the front and 20 x 10 in the rear. As I said, due to the fact that the suspension is ECE (4/6) on a '71 frame, I don't have your '73-'87 cross member answer. But, with the stockers, ECE drop spindle and rotor set-up, the trimming of the rotors is not an issue. 5 mins per side with a grinder. I don't have the front clip on yet, so I "doubly" don't have the answer on the front, other than the grinding (trimming) issue. But I'm running 245/40's up front and 275/45's out back. On the Fleetside, I decided another inch would look better, so I bought one inch spacers. Again, I'm still in the dark on the backspacing of the 20's and would have to measure. But if they are STANDARD in backspacing, with a 6" drop on a 1/2 ton Fleetside, that tire size in the rear works without the spacers by about 3/8" clearance to the inside wheel well. And, it works perfectly and (to my taste) looks better with another inch in width. An added benefit is this set-up gives more clearance to the inner wheel well. No problem with the outer fender-well clearance. In the pics, you can see the difference with the spacer (middle pic) and without (full length shot). Remember, the truck is in the air. But I have the jack-stands under the trailing arms to spring the load. The clearances stated are with the wheels on the ground. If this didn't help you, at least maybe someone else can use the info. And maybe someone else can chime in on any backspacing options available from Boss 338s. On the 20's at least.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 02-14-2011 at 02:02 PM. |
02-14-2011, 02:08 PM | #6 |
I am nowhere even close to you guys, but .. it will be someday. I am just undecided on a semi-stock look with rallys and just bigger tires (255/70 and 235/70 now) .. or to slam it with 20's. I absolutely love the way yours sit though (both of them)
Mine is a frame off project I bought from a guy in KY. He had done all the rust repair and metal work as you see it, I have just had it long enough to start dropping the engine / trans in the frame rails. My plans are to fit / block all my metal like this and then pull it back apart after final sand. It will be painted in pieces and raptor lined / lizard skin once the weather gets a little better. I am 80% sure it will be hugger orange with a white top and white 68 style grill shell. My other options are a special mix really close to marina blue, or butternut yellow. We'll see how it goes. I hope it turns out half as good as you guys have yours. Later.
02-14-2011, 02:52 PM | #7 |
slammed with 20's,mine was stock before dont think it will ever be stock again. i personally like the orange and white.
