vintage air a/c clearances?
it's time to figure out what way to go with the a/c. so....
has anyone used the super size? 24" long, or the compaq, 20" long? once installed, how much room from the unit to the glove box door? enough for a hidden radio? , what's the difference in the binary and trinary switch?..what about compressor brackets? I will need to move the alt on the 350 over to the dr. side, |
Re: vintage air a/c clearances?
I have the unit that's made for the TF truck, and no radio going in the glove box at all.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
![]() Join Date: Mar 2007
I would have almost no room for a stereo in my glove box. It is hard to tell how short my glove box will be until I finish the install.
If you are running electric fans you will need a trinary switch. If you are running a fan driven off the water pump you will use a Binary switch. I could sell you a binary switch if you need one because I ended up needing a trinary switch. As for compressor brackets my are from Street and performance because Im running an LT1 motor. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
