Old 02-14-2011, 04:44 PM   #1
biohazardbill
Bed Disassembly - Fleetside
Is it possible to disassemble the bed by unbolting? Or are there some pieces welded I will have to grind. The bed needs work and we are trying to save some space so we figured disassembly would allow us to stroe pieces til they are needed.
biohazardbill is offline   Reply With Quote
Old 02-14-2011, 04:45 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Bed Disassembly - Fleetside
If it's the same as a '67-'72, it's all bolts except for two welds at the rear crossmember that need to be cut out.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 02-14-2011, 04:54 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Get a bunch of PB Blaster!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-15-2011, 01:43 AM   #4
Captainfab
60-66 Nut
All bolts except for 4 welds at the rear sill to bedsides. One ~1" at the top both sides, and one ~4" long on the backside right below the tailgate. The easiest way I've found to grind out those welds is with a 4-1/2" grinder with a cutoff wheel.
Old 02-15-2011, 09:44 AM   #5
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I will tell you now GOOD LUCK!! My daughter and I took apart her bed a couple of weekends ago.
As Captain Fab stated, the only welds were in the back. Unfortunately on hers we had some damage on one side, and the hinge on the other side that prevented us from getting the 4 1/2" cutoff wheel in there, so we scored it as much as we could get to with the wheel, then persuaded it off with a BFH and a cold rolled chisel. Probably made more work for myself, but it was all I could think of at the time. I didn't know what was behind there, so I didn't want to use a sawzall.
We started unbolting all of the wear strip bolts, and got through about half of the bed, before giving that up. Then we just broke out/chiseled out the wood, and used a cutoff wheel on the bolts. We were trying to save the wear strips. Soaked them down with Liquid Wrench, and let them sit for a week, then put the head of the bolt upside down in a 9/16" 12 point socket, and wacked them with a hammer (using Captain Fabs suggestion). They all came out. You can see pics towards the end of her build thread listed below.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 02-15-2011, 12:35 PM   #6
JGross
One of the welds is here the other is on the face of the crossmember just below this weld.
JGross is offline   Reply With Quote
Old 02-15-2011, 02:27 PM   #7
SIR
SIR
SIR's Avatar
....stuff you WILL need to do the job... 1, sawzall and several GOOD blades
2, 4 1/2 " grinder with good cut off wheel
3, SAFTY GLASSES!!!!
4, B.F.H. (self explanatory)
5, COMPLETE FIRST AID KIT
6, PATIENCE,PATIENCE,PATIENCE!!
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
