Firefighter
DIY4x FGB52 kit question
Any of you guys that have used this kit on a 2wd to convert it to a 4wd, how did you locate the position for the rear spring hanger? Does one of the bolts go through the bottom of the front cab mount where the rivet was, or just in front of it?
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Firefighter
Re: DIY4x FGB52 kit question
Anybody???????
Moderator
![]() Join Date: May 2007
moving to 4wd area...hopefully someone here has your answer.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I dint quite understand your question. I just measured from the front of the frame for the shackle eye hole.
Posted via Mobile Device |
Enjoying left field
Have you called Kert at DIY4X? He's pretty helpful.
Yes the front cab mount needs to be trimmed.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Firefighter
So one hole is actually lined up with the old rivet hole in the lower part of the front cab mount then? What about the front hanger does it just bolt on where the old mount was, or does it need to be relocated and holes drilled?
The front spring mount and the core support are welded as one so the core support stays in the same location.
Do this he can tell you
nickle and dime |
