Old 02-14-2011, 10:02 PM   #1
brans72
Who sells wiring adapter for steering column???
I'll make it quick here!!!! I know ECE and CCP makes them but I wanna find one cheaper then $40 plus shipping. Wiring adapter for van steering coulmn to 67 C10 turn signal harness. Brandon
brans72 is offline   Reply With Quote
Old 02-14-2011, 10:33 PM   #2
mr48chev
mr48chev's Avatar
Re: Who sells wiring adapter for steering column???
[I]I think that is what you are looking for http://www.tuckersparts.com/Turn-Sig...s-Adapter.html
I think it is in most of the aftermarket suppliers catalogs.
You might also check with NAPA as they have it in their replacement turnsignal switch for the 71 http://www.napaonline.com/Search/Det...+50014+2014024 and I am thinking that they have it in their service line in the electrical catalog. They might also have it in the Help line.
Or I think this is the same one. http://www.rickscamaros.com/camaro-t...1967-1968.html
Old 02-14-2011, 10:51 PM   #3
Hart_Rod
Hart_Rod's Avatar
Are you talking curved to flat like the newer style? If so, I'll ship you one for $10.
Hart_Rod is offline   Reply With Quote
Old 02-14-2011, 10:56 PM   #4
brans72
flat to like semi round? post a pic, but I am pretty sure wht your talking about is right!!!!! I want it if you can post pic. Thanks alot guys!!!!!!! Brandon
Old 02-14-2011, 10:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
walk into your chevy dealer
Old 02-14-2011, 11:20 PM   #6
Hart_Rod
Hart_Rod's Avatar
Old 02-15-2011, 11:01 AM   #7
jmdemon55
jmdemon55's Avatar
dont mean to threadjack here, but is this the only part needed to get a 79 van tilt column to fit into a 70 1/2 ton? are the mounting brackets under the dash and the steering box or ragjoint the same or do you have to modify this as well?
jmdemon55 is offline   Reply With Quote
