power steering pressure line
i need a new ps pressure hose, id like to just get a factory style hose, what is on there now is a cut to length steel braided deal, with a banjo fitting at the pump end, and a factory line has a female flare fitting on the pump end, so in order to utilize a factory line do i have to get a different pump or is there a fitting im missing? thanks
![]() Join Date: Jul 2007
Re: power steering pressure line
You can just swap the valve (fitting) in the back of the pump to the flair style. Takes a one inch wrench.
where do i find this fitting for a saginaw pump, almost looks like in the picture of the factory hose that it comes with a fitting thats straight on one end and a male flare on the other
