Old 02-15-2011, 02:04 AM   #1
rideorange812
frame off restoration questions
where can i find a guide to mark my frame and the correct colors for all the misc frame parts and what not. please give me a guide in direction thank you.
rideorange812 is offline   Reply With Quote
Old 02-15-2011, 02:23 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: frame off restoration questions
I went on the same quest a few years back (but lost interest in the excitement of my truck running).
I would go to the TOTM area, look for the bone stock trucks and see if those members have some research they would share.
True to stock restos are a class in themselves. Have fun and post up some pics along the way!
Subscribed!!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 02-15-2011, 02:39 AM   #3
sameyrasmea72
sameyrasmea72's Avatar
Alot of semi-gloss black and cast iron color and you will be good to go.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-15-2011, 10:30 AM   #4
Duncan and son
Jason probably knows as much about "correct" restoration as anyone on here. His truck will have all the correct stencil and grease markings. There are several more... Dan Tippmann and Harold Shepard to name a couple.
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 02-15-2011, 01:51 PM   #5
NoNeck
NoNeck's Avatar
I don't know if this helps, but when my son and I were restoring our first 1969 Camaro we researched all the correct finishes for the subframe on a concours resto. I would expect some of the specifications would carry over to the C10 pickup (or at least the 1969). At the very least, these specs would result in nice, original looking frame.
The frame was painted using Ditzler DAR-9000 with 33% DX 265 flattening compound.
The upper and lower A-arms use the same DAR 9000 with 25% flattening compound.
The steering box is natural. The upper cover is aluminum with zinc phosphate bolts. The natural finish was covered with a layer of Cosmoline lubricant (to inhibit rust) from the factory.
Upper control arms were generally about 33% gloss, but they can range all the way up to 100% Gloss (whatever GM had on the shelf that day). The washers on the control arm bushings are unpainted. The disc brake setups used gold cadmium caliper brackets with natural color calipers, rotor and spindle. The mount on the frame for the brake line is dipped in black paint and uses a zinc phosphated bolt. The washer and bolt atop the shock mount are both cad plated.
The lower control arms were gloss black and the steering linkage is natural. The cross shafts were sometimes painted with the upper control arms, but in most cases were natural. The alignment shims were unpainted and finished in silver cadmium. The studs that mount the upper control arm to the frame are zinc phosphated and use a locking nut that is cadmium plated.
The steering arm that bolts to the back of the spindle is natural finish. The lock nuts that hold the steering arm to the spindle are silver cadmium. The bolts are zinc phosphate. The drag link, idler arm and tie rods are natural finish.
The backing plate for the brake rotor was cadmium, although some were natural. The ball joint nuts could be cadmium or natural. The stabilizer bar is natural, and the stabilizer link is cadmium plated. The stabilizer link stud is zinc phosphate with a silver cadmium washer and a cadmium plated nut.
Factory wheels were dipped at the factory in 70% gloss black paint, then the front side would be painted body color (or argent silver for the rally wheels). Overspray on the back side of the wheel should be hardly detectable.
The coil springs are a natural finish. Most, but not all, shocks were a flat, dark gray.
Information I have on Inspection Paints:
Chevrolet Orange - DQE 60339
Identity White - DAR 8367
Yellow - DAR 81348
This info was compiled over 15 years ago, and paints and processes may have changed. There may well be a more complete, concise database on these paint specifications.
Just trying to help... I am NOT an expert!
Thanks - NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 02-15-2011, 02:49 PM   #6
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Good info Noneck!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
