Old 02-15-2011, 08:06 AM   #1
tjvending
tjvending's Avatar
Hauling a 8ft bed on a 6ft wide trailer
Any sugestions on tying down a 8ft bed on a 6 ft wide trailer? will be about 500 miles on interstate 95. TJ
tjvending is offline   Reply With Quote
Old 02-15-2011, 08:12 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Hauling a 8ft bed on a 6ft wide trailer
Upside down, not sideways, and secured with a few rachet straps.
Old 02-15-2011, 08:16 AM   #3
Liddy71
Liddy71's Avatar
if it has a rail sides on it lay some 2x6 across and on the inside of the rail screw some 2x4 lenght of the trailer on the inside of the rail and this will keep them from going sides ways . turn the bed upside down and strap it down good
Liddy71 is offline   Reply With Quote
Old 02-15-2011, 08:41 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
yep.....like mentioned above,...just put some timbers...I always use 4x4's, across the trailer and run the bed longways...you will be fine. Check your straps every 100 miles.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-15-2011, 09:04 AM   #5
tjvending
tjvending's Avatar
On a trailer with sides (6ft) , should I lay one side down on the floor and the other side angle up on the boards or lay board all the way across and then tie bed (6'6")to the top?
Old 02-15-2011, 10:37 AM   #6
I'd put boards across the rails,side to side,and strap the bed upside down on top. Basically,treating it as a flatbed. I'd run the straps front to back to avoid body damage. If you don't have the wide (2.5-3") ratchet straps,I'd invest in some to assure a safe ride home.
