02-15-2011, 02:12 PM | #1 |
63 GMC Closed Knuckle D44F Swap to open knuckle?
Hi Folks,
Does anyone know if there are years of front open-knuckle D44s on Chevrolet or GMC trucks that will swap with my current closed-knuckle on my 63 GMC 3/4T 4x4 without cutting/welding etc.? Is there a straight bolt-on swap out there? If so, what years/models might they be? Thanks!! Last edited by Teech; 02-15-2011 at 02:26 PM. |
02-16-2011, 01:28 AM | #2 |
Re: 63 GMC Closed Knuckle D44F Swap to open knuckle?
I picked mine up from a '72 3/4 ton. It was an easy swap even though I went from 1/2 ton to 3/4 ton. I think I remember brake lines being an issue.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
02-16-2011, 08:42 AM | #3 |
You can use a axle up to 1987 and it will bolt in. When you go from drum to disc brakes that is the big change as ie brake lines,master cylinder, ect.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-16-2011, 10:20 AM | #4 |
Thanks guys. Up to '87: Good to know! I'm prepared for all the mods to switch to discs...I don't have the parts yet, but I know what's in store. Thanks again.
02-21-2011, 12:53 AM | #5 |
Born Psycho
axle is a bolt in swap, brake lines are definitly different and the steering will be a lot different. we used a 72 p-s box on my nephew's 63. had to modify the column and space the box away from the frame. not a big problem but took a little time to get everything right. he's put well over 100K on that truck since we built it several years ago.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
02-23-2011, 10:50 AM | #6 |
Thanks Jerry. Fortune has smiled on me: the truck already has later model power steering! I'm doing a complete (mostly) rebuild, so the brake lines should be no problem. 100K miles on your rebuild? That's great...I hope to do the same. Thanks again.
