whats a wrench
Looking for a crate 350
Hey guys! Well it looks like its time to buy a NEW 350. I finally ran mine to the ground. Its for my 69 Longhorn. Im still gonna be working in this truck and using it as my daily driver. Alot of people are telling me that I need a 4 bolt main because of the load I put in it and the things i haul. I dont plan on loading it as heavy as I use to, but there is diffidently gonna be a skid of plywood, couple squares of shingles, or a few kegs of asphalt back there at any given time.
So my questions are: Do I need a 4bolt main and where is a good place to find one. Not looking for nothing fancy. Just a good, new, strong 350. any advice is welcome. Thanks in advance Laz
69 longhorn 350 headers 4 on da floor |
Re: Looking for a crate 350
the 4bolt main is mostly hot air and myth for street driven vehicles
your local GM dealership is a good place to get a great crate at reasonable price//do comparison shopping online frst and dont b afraid to talk to them about matching prices or better yet get an old senior citizen to use their AARP discout to bring down the price
whats a wrench
Thanks CDOWNS! Mostly everything leads me to GM Performance parts. they are telling me that the 4 bolt main is about 25% more powerful??? Isnt the 2 bolt powerful enough?? I dont much bout this. thanks again
its all about the +6 inches
2 bolt verses 4 bolt doesn't make or take any power at all. Ignore 99% of what you hear the average person (including salesmen) will tell you.
The added bolts help keep the engine together at stupid high RPMs (like over 5500) and also they help with real high cylinder pressures, like 450 horses or more. On a street driven truck, it's nothing but talk. Think of it as putting a double knot on your shoes, even though they never come untied to begin with. |
![]() ![]() Join Date: Jan 2011
For what it's worth to you, and to no offense of the guys why might have them.. I personally would steer clear of the 350/290hp crate engine from GMPP.
While yes, they offer a 12/12,000 warranty - it's only good if a certified ASE mechanic installed the engine. I personally had one in a 69 Camaro and put about 1,000 miles on it. It started smoking, just slightly at idle. I thought it was just running rich at first and was trying to adjust the carb. It started loosing power, and the smoking got worse. I started to do some research online and found that there were a bad batch of these motors built and they caught the problem a few weeks after the engines left the Mexico assy plant. As it turns out, someone apparently used the wrong valve seals. I was one of the lucky ones who got one. I pulled the valve covers off and there were pieces of valve seal all in the top of the head. It was a mess, and I have pictures if you'd like to see. As soon as I replaced the valve seals with the correct ones, the power came back and the smoking went away. Not a big deal, I know .. but just make sure you're ready to change valve seals if you go this route. You may not get one of the bad ones, but they are out there. On a good note, they like to run 32-34deg fast / btdc. They have a pretty nice sound to them too. I ran an Edelbrock 1407 and RPM intake with shorty headers and Delta40s and it sounded really good. They're strong motors, no doubt. I'm just a little bummed with the QC in the assy plant. I agree. Unles you'll be turning this motor hard, a 2 bolt main will be fine. The 350/290hp is a 4 bolt block though. I hear with a good set of 64cc heads and a slightly bigger cam there are guys pulling 400+ hp out of them. Hope this helps. .. but I wouldn't buy another one personally.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
I have used & installed for customers hundreds of the basic 350 260 HP & 292 6 cyl engines in up to 1 ton trucks. I have never had a bad one. You put em in start it up set the timing & drive it out the door down the highway. They come with 4 bolt mains but like the guys say it is not nessesary. I have one in my 70 that I use for a partial DD. It idles smooth you can't tell its running & will go out & get 18 mpg.
The basic GM 350 crate is probably just fine for what you want. As said above, 4 bolt mains are nice but not required; that engine has them.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
86 Scottsdale
for a simple swap on a cruiser, I'd use gm part #10067353.
If there's a bad one in Summit's warehouse, I'll be the guy that gets it. Every time. Maybe I was just un-lucky but I definately got a 350/290hp crate engine with V6 valve seals in it. and, they weren't even all the same.
Just my experience but you'll probably be fine with anything from GMPP.
#10 | |
if anybody wants to read http://www.crateenginedepot.com/pdfs...ne_Warrant.pdf
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 02-15-2011 at 06:28 PM. |
whats a wrench
Thanks for the feed back fellas! I contacted GMPP and the have an option of a 350/290 from GMPP and a 350/190 remanufactured. $three hundo price differance.
The 350/290 is $2,321.81- out the door for the block and heads. Posted via Mobile Device
![]() Join Date: Apr 2008
I am thinking a twin turbo 572.arent all daily drivers suppose to have 1000 plus HP?
#13 |
"something witty here"
Have you considered a ls swap? I had saved up what I wanted to spend on a 350 ho crate from gmpp, around 7k when all said and done. I was just about to get ready to order one last week, when the thought of a ls and mated tranny came to mind. After searching there was a 10,000km ly6 for 2000$ only a few hours away. And the allison 6spd for 1200. Both only two years old. Now it doesnt come with a warranty, but for the price of a decnt crate motor I could get this combo, only thing needed is a wiring harness. My dad has this motor in his dd and it has gobs of power and gets no less that 18mpg. Just a thought to consider...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 02-15-2011 at 08:30 PM. |
#14 |
cdowns - Just going off what I was told by Summit Racing, right or wrong I got a bad one and no warranty support at all. For this reason I wouldn't buy another one. If he does, I'm sure it will be ok .. and .. I'm just saying. ..
I understand there is a bad batch of them out there and I hoped he didn't get one. http://www.chevytalk.org/fusionbb/sh...hp?tid/181952/ Specifically the post by 'Bent Rod' (not me..) and the ones below it.. I have pictures of my valve seals and they look exactly like these in this picture. I replaced them and the engine is fine now. I have had this engie for several years so I think the run would have been 2006-2007 or so. Just interesting to know.
#15 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm gonna go against he grain on the 2 bolt vs 4 bolt deal.
There is something to 4 bolt engines. They are designed for higher stress applications. Look at it this way, GM put them in applications that typically saw heavy usage. They don't spend a single red cent on something unless it makes the vehicle they build have fewer warranty claims. If they felt the average 3/4 or 1 ton truck could get by on 2 bolt engines as well as they could 4 bolt engines they wouldn't have bothered to use them at an added cost to production. Simply stated they equipped hard working trucks with 4 bolt engines because the engineers fell the beefier block offers improved reliability and suffers fewer warranty claims. Fortunately, the basic Goodwrench 350 comes with 4 bolt mains, an unbeatable warranty, and it's very cheap.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 02-15-2011 at 10:18 PM. |
#16 |
Farm Truck
![]() Join Date: Aug 2006
Just about all the GM crate motors are 4 bolt main?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#17 |
The performance GM crate engines and the basic Goodwrench engines are 4 bolt. But, GM sells a whole metric boat load of Goodwrench engines in all configurations. One of the most popular ones is the basic centerbolt head 2 bolt main 350 engine for half ton 87-95 trucks.
#18 |
his own description of 'working it' doesn't sound like he needs to double tie his shoes though.
#19 | |
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#20 |
Whats the internal difference between the 350/190hp and the 350/290hp motors?
1969 Chevy c20(Miss Hackjob) |
#21 | |
Now, if he were building a work truck for idiot employees to use pulling a load all day, I'd say push for a 4 bolt bottom end.
#22 |
Did you check out Year One's 350 Crate Engine? It is over 400HP and loads of torque for 2,900 bucks! It comes with it's own Dyno Sheet.It's a lot of motor for the money!
#23 |
#24 |
![]() Join Date: Aug 2007
Got mine from these folks: http://sdparts.com/details/gm-goodwr...gines/10067353. Shipping was about $100.00. Great Service. They have a number of different kits you can get with it.
![]() Robert 71 Chevy SWB |
#25 |
