Old 02-15-2011, 02:36 PM   #1
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Rear suspension travel with Firestone F9000 bags
I read on the Firestone website that these bags are 10.25 inches fully inflated, 8.25 at ride height, 6.25 fully deflated. If I install these almost directly over my axle what kind of suspension travel will I have? 8.25 - 6.25 = 2 inches??? That doesn't seem right. I think I want them at the axle (1 to 1 ratio) so I can haul heavy loads. I am also wanting the smoothest ride possible with an empty load. Help me understand please.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-15-2011, 03:04 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Rear suspension travel with Firestone F9000 bags
They have much more travel than that I would say 6-8 inches at least. I have mine mounted in a 1:1 set up and they ride awesome. No better bag on the market when used in the rear IMO.
Drew I was just checking out your gallery trying to figure out what you were building. Your shop is awesome! I;ve been in the planning stages for mine, what size is yours, and is the upstairs big enough for a pool table??
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-15-2011, 04:18 PM   #3
robnolimit
robnolimit's Avatar
should be 4.5" closed, 12" open, RH at 9 - 9.5", 1500 lbs cap at 100 psi. This is the bag i'll be using on the back of our JT project.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-15-2011, 05:09 PM   #4
tech@scottshotrods
rob is correct the proper ride height for this bag is 9-9.5 don't worry about pressure be it 15psi or 115psi make sure the bag is at the 9-9.5 installed ride height, weight will determine the actual pressure which will vary underload.
tech@scottshotrods is offline   Reply With Quote
Old 02-15-2011, 05:12 PM   #5
drewskiren
drewskiren's Avatar
My shop is 28 by 36 with an upstairs apartment to house missionary families when they come back to the U.S. The apt. has a full kitch and bath - 800 sq. feet. Across the rear roofline is a nearly full width dormer to give me a lot of 8 foot tall area.
Drew
Old 02-15-2011, 05:27 PM   #6
drewskiren
drewskiren's Avatar
Thanks for the responses, not sure why the Firestone site has those specs.
Drew
