np205 10 spline flange
ok, lifted my truck, old front shaft doesn't fit. got a shaft from a np203 th350 truck, a little longer than mine. now i have the early 205 with the yoke mount front (10 spline), and the new shaft has the flange mount shaft (30 spline), question is, does anyone make a 10 spline flange mount for this t-case? i don't want to tear the t case apart to replace the front output if i can just replace the flange.
I had the right to remain silent, but i didn't have the ability! 78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines 79 Chevy Monza:current plans, dz 302, 4 speed 69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher |
![]() Join Date: May 2003
Re: np205 10 spline flange
Not that I'm aware of. I also made this swap but had to replace the front output shaft.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Try these guys:
http://www.advanceadapters.com/ I didn't look to see if they have a solution for your problem but they are worth checking out. I have used them a few times. They have some good stuff. |
