Old 02-15-2011, 08:11 PM   #1
sjarrett71
sjarrett71's Avatar
Tilt Indicator Light Wire
Got my tilt column installed and now I need to know where to plug the gear indicator light wire into. Any help out there? Would it plug into the cluster feed?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 02-15-2011, 08:36 PM   #2
JimKshortstep4x4
Re: Tilt Indicator Light Wire
if you look at the fuse panel there is a male terminal that the gray wire plugs onto close to the fuse marked "panel lights". This way the tilt light will dim with the panel lights.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-15-2011, 08:39 PM   #3
sjarrett71
sjarrett71's Avatar
In the pic that is posted, is it the male terminal to the right (between the panel light and cluster feed) or underneath the panel light fuse (the one by the fuel gauge terminal)?
-Scott-
Old 02-15-2011, 08:40 PM   #4
JimKshortstep4x4
That is the one to plug into.
Jim
Old 02-15-2011, 08:50 PM   #5
sjarrett71
sjarrett71's Avatar
Ok, I went out and looked. There is already a wire coming off that terminal with a female end spliced into it from the factory that the column wire fits into. Thank you.
-Scott-
