Old 02-15-2011, 09:18 PM   #1
78customdeluxe
towing bags
Firs i'll just say i'm bringing this over from the suspension forum to hopefully get a better response
I know I have multiple options on what I want to do. I've got the truck in my sig, 1988 crew cab dually 4x4. I need to lift the rear after the 4x4 swap, and I thought while I was at it to go with some sort air ride setup, partly for the ride quality, and mostly for the variable hauling capacity. I havnt been able to locate a 4link setup that would be heavy enough for what I want for my body style truck. The bag part i'm not worried about fabbing something up with, just want something heavy enough to hold the axle from twisting under the torque of the cummins infront of it.
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
Old 02-16-2011, 06:56 AM   #2
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: towing bags
How much lift are you looking for? Depending on height, what about incorporating a trailing arm on a shackle into a lift block. You could use 2x3 tubing or so if that would give you the lift you need and run a length of that tubing up to a shackle mounted on the frame or a crossmember up front of the axle. If it was enough lift, it would also help with axle wrap and not sacrifice any movement of the stock suspension
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-16-2011, 08:19 AM   #3
78customdeluxe
Re: towing bags
The truck will be going up around 6 inches because I had to raise it up from the 4x4 swap and a little more for the axle to clear the cummins pan. I'm a little confuesed and trying to picture what your talking about. Are you saying removing the leaf springs and going to a trailing arm setup similar to the 67-72 2wd trucks? only not running them at an angle in? If so I had thought about that but was also worried about pinion angle as the axle moves up and down... If I do go this route i'm not worried about making some drop mounts for the trailing arms, I can fab somewhat, getting better all the time. This truck will be on the road most of the time, but its also a farm truck so mostly flat fields will the the extent of off road time, except for the occasional creek i'll have to cross to get to a field.
Old 02-20-2011, 09:27 PM   #4
modblacksmith
modblacksmith's Avatar
Re: towing bags
I would go with the four link with a beefy panyard bar to keep everything in line. You can buy some huge heim joints from 4x4 shops that will hold up to that Cummins. Check out Keldermanairride.com for ideas.
modblacksmith is offline   Reply With Quote
