02-15-2011, 09:44 PM | #1 |
3/4 ton Hub ?
I want to swap hubs.
I want the big 6 bolt flange hubs. I just like the look. How can I do it. NOW WHAT I WANT
2003 Nissan Frontier Crewcab 4x4-Daily 1982 Chevy Suburban 3/4ton 4x4, Mud Toy Lookin for a C10 |
02-15-2011, 10:41 PM | #2 |
Re: 3/4 ton Hub ?
I'm no expert, but you probably would have to change the spindle at the least. Maybe the knuckle too if the bolt pattern is different. The stub shafts shouldn't be any different. Is that 6 bolt setup a ford or something? I like what you have now, just cuz it's not all rusty
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) Last edited by skoffice; 02-15-2011 at 10:42 PM. |
02-15-2011, 11:30 PM | #3 |
thinair
Re: 3/4 ton Hub ?
change the spindles outward.
02-16-2011, 12:04 AM | #4 |
Certified Hobbiest
Re: 3/4 ton Hub ?
Agreed. When I did mine, I swapped everything from the spindle out...spindle,backing plate, hub/rotor and lock outs.
Posted via Mobile Device |
02-16-2011, 12:25 AM | #5 |
Currently Blazerless
Re: 3/4 ton Hub ?
You should be able to get by with just the wheel hubs from a 71 to 76 K-20 and depending on what you have now you may need the spindles from the same. Rotors and backing plates you have now will work...then get a set of Warn 9072 locking hubs and that should do it.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
02-16-2011, 11:49 AM | #6 |
Re: 3/4 ton Hub ?
Ok thanks im on the look out for 70's hubs
02-16-2011, 12:59 PM | #7 |
Re: 3/4 ton Hub ?
I've got a couple sets of the hubs for sale, check the classifieds there was another board member selling a set if I remember right. 70BlazerXXXXX?? It was something like that....
02-16-2011, 07:26 PM | #8 |
Re: 3/4 ton Hub ?
If I'm not mistaken, the hubs you like the look of so much are conversion hubs for a truck equipped with a NP203.
02-16-2011, 07:43 PM | #9 |
Re: 3/4 ton Hub ?
http://67-72chevytrucks.com/vboard/s...d.php?t=427704
No idea how you make the link clickable. It was 72 Longhorn I was thinking of.... |
02-16-2011, 09:53 PM | #10 |
Re: 3/4 ton Hub ?
I'm pretty sure they are Warn 9072s, these were a replacement for the big Spicer external drive hubs used from the early 60s to mid 70s on Ford, IH, Dodge, Chevy and Jeeps
02-17-2011, 12:35 AM | #11 |
Windy Corner of a Dirty Street
Re: 3/4 ton Hub ?
I agree, looks wise the big hub 44’s are interesting to look at and “look” mean. Functionality wise, they are no better or worse than the rotor/hub assembly in picture 1.
I also agree with Blazerman…..
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-17-2011, 12:48 AM | #12 |
Re: 3/4 ton Hub ?
Thanks for the link
