Old 02-15-2011, 09:45 PM   #1
del
add a leaf for 1959 pickup
Does anyone know if there is a add a leaf kit or another way to carry a heavier load for a 1959 pickup? Thanks
del is offline   Reply With Quote
Old 02-16-2011, 05:41 AM   #2
dicer
Re: add a leaf for 1959 pickup
I'm sure they still have helper springs. Start with a place like JC Whitney. And I suppose you could just ad a spring or two as well. Or you could add airbags, they make some just for that purpose, to help with the weight and level the load out.
dicer is offline   Reply With Quote
Old 02-16-2011, 11:26 AM   #3
mr48chev
mr48chev's Avatar
Hellwig http://www.hellwigproducts.com/ Probably has something that will work but they don't list one specifically for that truck. There is usually a place in most towns that sells their stuff though. They have the add a leaf and the axillary air bag setups that are overloads.
Old 02-16-2011, 03:05 PM   #4
OrrieG
OrrieG's Avatar
I packed quite a bit of weight in my stock 1/2 ton by adding standard air shocks. In the attached pic I have a about 750 pounds with camper and stuff inside and you can see it is sitting level even with two adults, two kids and full tank of gas. One time I ran it over the dump scales at over 6K (lots of concrete debris in the back), it was down a little bit in the back and it still had not bottomed out. When you don't need the lift you can air them down and they work like stock shocks.
OrrieG is offline   Reply With Quote
