Old 02-15-2011, 10:55 PM   #1
BP68
BP68's Avatar
Help - how to disassemble a tilt column?
Hey all, I did not install my rubber seals when the column was apart. Now it is back together and I can't remember how the metal ring/cover around the turnsignal switch comes off. I tried a gear puller and the ring started to bend at the edges.
Pics would be great. I could not find what I was looking for doing a search here.
BP
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 02-15-2011, 11:54 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: how to disassemble a tilt column
First remove the turn signal switch, with that out of the way insert a square sided screwdriver or punch through the hole in the side of the cover where the turn signal lever goes then gently pry upward, this should get it started and then you should be able to get it off by hand from that point. hope that helps, good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 02-16-2011, 02:08 PM   #3
SOON2BLAZE
SOON2BLAZE's Avatar
Pay attention to the "shoes" for the tilt. the 2 little grooved pieces that determine the position the tilt is locked at. one has an extra groove in it IIRC. Search Yukon Jacks posts, he had a good post on tearing one down ( including pulling the pins on the side to get to the guts)
SOON2BLAZE is offline   Reply With Quote
Old 02-16-2011, 02:59 PM   #4
69sixpackbee
Here:
http://67-72chevytrucks.com/vboard/s....php?p=3216427
69sixpackbee is offline   Reply With Quote
Old 02-16-2011, 03:00 PM   #5
dadsworktruck
here are you a few pics to look at...
dadsworktruck is offline   Reply With Quote
Old 02-16-2011, 05:20 PM   #6
SOON2BLAZE
SOON2BLAZE's Avatar
that would be it.
Old 04-18-2014, 07:04 PM   #7
IHeartGroceries
Thread revival!
I'm tearing into the steering column on my 72 automatic w/ tilt...
I've got the cover/sleeve persuaded out (separated from the bowl), but in order to fully pull it off, it need to remove the tilt lever.
I can't see how it is attached or fasted to the tilt assembly/mechanism. The hazard lever and signal lever both had screws. Easy. The gear lever had a pin. Cool.
But has is the tilt lever attached?
Never been into one of these before. Who'd have thunk it was such a sophisticated little mechanical operation under there.
IHeartGroceries is offline   Reply With Quote
Old 04-18-2014, 07:14 PM   #8
29od1
Tilt lever screws out.
29od1 is offline   Reply With Quote
Old 04-18-2014, 09:57 PM   #9
BADAZ chevy guy
BADAZ chevy guy's Avatar
Video on turn signal repair. Should have all the info you need.
https://www.youtube.com/watch?v=1CYQ0-Qd708
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-18-2014, 10:38 PM   #10
southern parts
southern parts's Avatar
a small slide hammer (dent puller ) works good on removing the pins. be sure to remove the tilt spring first.
southern parts is offline   Reply With Quote
