my wintertime time killer
so my engine crapped out again, i cant complain much it last a couple of years and i bought it straight from the junk yard and put it straight into my truck. so this time thanks to dad (sammy) we found a 350 on craigslist. The guy that had it acquired when buying out a garage and didnt know anything about the engine. it looked like a fresh rebuild with assembly lube visible visible in all the right places. it was minus the intake, oil pump, valve covers and oil pan. So a deal was struck and we took it home, it even came with the engine stand. so now to the fun part removing the old and in with the new. even with heat in the garage there hasnt been many decent days to mess with it but here is pics to show what we have done up to now.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: my wintertime time killer
Cool deal...saved you lots of time too! Subcribed.
the numbers show a 4 bolt main truck engine, the heads are from a 400, we have been slowly adding parts to it from the old to the new, you can see half of the serpentine set up here
and a few pics of my truck taking up space in dad's garage
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride Last edited by firedog; 02-16-2011 at 12:03 AM. |
its all about the +6 inches
Looks sweet... I'd remove that fram paper weight off of there though.
Nice weather 75 today. Added the other Serp bracket, WP, cleaned the Intake up with some cleaning n paint, used a can of carb cleaner on the carb. Alls left before install is torque the intake, add the PS Pump, finish installing the Dampner (need to rent the tool), plugs n wires and dist., and adj the valves. Clean n prep the truck frame of gunk.
See if I have an update pic. Fram is for intial run. #8 Rod on the ol motor is toast with about 1/16th inch of play.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Details on replacement engine: New ..cam, lifters, push rods, crank, rods, pistons, dbl roller timing gear, and freeze plugs. New bearings cam, crank etc. Block was machine shop cleaned. Heads have new valves with springs and have been been reworked. Everything clean as a hounds tooth on a hot August day.
Updated pics added.
Wow thanks dad I spent the majority of the day sleeping... Two more night shifts then back to days and the way normal people live
I noticed you are saving the power steering pump for me...
No...actually needed to sample a cold beverage..haha
well no progress this weekend so far... however headed to a swapmeet tomorrow to look for goodies... hopefully the "early spring" continues so we can get back at it this week
Grandpa in the rustmobile...
I hear the early spring, weather rocks here this past week or so!
Motor looks really good!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#13 |
Looks good man. Parents just ordered a camper from down by you guys. Did you get it all put together? Oh and did you get an exhaust with a little higher ground clearance put in?
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 04-20-2011 at 08:29 PM. |
#14 |
hey; firedog nice project. i just got some brackets and pulleys out of wrecking-yard like yours . and went to my local Chevy dealership and ask if there was an a/c compressor delete and he said no that the only difference was belt length . and i was checking out your thread. and seen yours.and sammy's too. is my parts-man wrong? or did y'all make your own? i also picked up another bracket without air-pump provision. please help...thanks
#15 | |
#16 |
http://platinumparts.com/da-1698-2100002.aspx here is one but I didn't see a price. You can always get a part number off one of the sites and shop around or even order thru your local guy too. Good Luck.
#17 |
the boat guy
no more slow truck!?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#18 |
Actually have run into a stumble..not sure yet about the valve adjustment and timing. Very hard to determine TDC with a serp system masking the timing mark. Battery giving us fits and my charger went dead. But shes pumping oil. Will revisit this W/E with the setback.
#19 |
hey/ Sammy. thanks for reply on a/c delete. i ordered one thru different dealer-ship.probably paid too much. didn't mean to get in yawl's way. but you've been helpful.thank-you . hope you get timing like you want....j.w
#20 |
NP..yeah I'm going to look at battery chargers that are on sale tomorrow. Maybe you can send some dry Tx weather up this way so I can get something done on Firedogs Trk.
#21 |
Looking good,truck looks good too.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#22 |
Well got the Timming and valves adjusted and it started!! Oh ya look out now sounds mean! Got a nice little lope from the cam I'm excited!!!
@*+=<\>%>!??\£]^¥¥£]%>€|*€\!!|€€{£ What's that under the truck? Oil leak!! Thought it wasthe oil pan crawled under took it down put it back together... I fire it up... Still leaking .... Grrr looks like I am gona have to do the rear main now! Add to that I threw my back out an not gonna be able to crawl under it for a few more days Posted via Mobile Device
#23 |
![]() Join Date: Feb 2001
Good thread-Good reading
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#24 |
The Older Generation
You guys better hurry... only four months left... ![]() LockDoc
#25 |
6>8 Plugless........
![]() Join Date: Sep 2007
I'm glad to hear you got it running. Sucks to hear about the oil leak. Good luck with it!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
