I would like to put relays on my headlights. Can someone tell me where in the lines to put them and how to wire the terminals please...thanks
Re: Headlight help
here is a diagram I have
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
Happy to be here
![]() Join Date: Mar 2000
Re: Headlight help
Heres another one...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-16-2011 at 11:30 AM. |
Re: Headlight help
whats the purpose for running relays?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
Re: Headlight help
When I bought the truck the po had installed these crystal white headlights, and i have already been through 2 diff headlight switches they keep melting. They last about 5 or 6 weeks then melt down.
![]() Join Date: Dec 2010
Re: Headlight help
stock output halogens the ($20 pair from AZone or Advance) are bright as day on low since I did the relays.
Now I'm wondering if I can put relays on the tails to make them stand out more (since I have '39 ford tails on the stepper) |
Happy to be here
Re: Headlight help
It allows a solid 12v to your headlights greatly increasing their lighting ability. This and the painted cluster mod are the best thing you can do to these trucks to improve safety.
Junior Member
Re: Headlight help
Is there a preferred place to get this kit - in other words, is any particular kit better than any other?
#9 | |
Re: Headlight help
painted cluster? is that so the cluster gets brighter as well?
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Headlight help
Yep. Disassemble the cluster and paint both the blueish white housing the gauges set in as well as the back side of the front cover(located between the clear lens and the gauges) GLOSS WHITE to get the most benificial use of the light output of your #168 bulbs.
In the past I've tried a variety of things to get my gauges to light up brighter. 1. CHanged all bulbs to 194's (Found out later 194's are a bit lower wattage/candlepower than the 168's) 2. Tried going with 921 bulbs much much brighter/hotter bulbs = Had to insert bulbs into sockets from the front as bulbs were too large to fit thru openings in back of cluster. Also bulbs started to melt cluster housing. 3. Tried "CHROME SILVER" paint = actually got darker/harder to see gauges. 4. tried FLAT WHITE & SEMI GLOSS WHITE paint = A bit better improvment than the factory. 5. L.E.D. BULBS = Not enough sideways light output for my likeing. worse than having 1 or 2 bulbs burnt out.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 02-16-2011 at 04:03 PM. |
#11 | |
Happy to be here
Posted via Mobile Device |
#12 | |
Junior Member
Re: Headlight help
I'm driving this truck several times a week, so this really should have been the first thing I did... |
#13 |
Re: Headlight help
gonna follow this one. gotta try the cluster thing soon. and had no idea about relay. no electrical experience here. hopefully someone will post a step by step
#14 |
Re: Headlight help
here is a link with some info about installing them http://67-72chevytrucks.com/vboard/s...d.php?t=182351
#15 |
![]() Join Date: Jul 2010
Re: Headlight help
I was wondering tha same thing about tha tails also..
#16 |
IT Guy/ Father/ Chevy lover
Re: Headlight help
I just replaced my headlights with Sylvania xtras's and I didn't notice any real improvement in the output. So this would help with the output correct?
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino ![]() Technology Specialist aspiring to be a gear head. ![]() |
#17 |
Re: Headlight help
guys I just noticed that the relays in the diagrams are 4 prong and not 5 prong. Would it matter and could a 5 prong be used since I have a bunch of 'em. You would just have an unused wire...right?
#18 |
Moderator
![]() Join Date: Oct 2008
Re: Headlight help
The 5 prong relays are SPDT and the 40 amp versions are cheap. The standard Bosch or ISO relay sockets have 5 holes but there's no reason that both 87 & 87a have to be wired.
