Old 03-16-2003, 02:40 AM   #1
DRASTiK
Converted Ford guy
power steering box
on my 84 Suburban, the steering box is leaking. Most people that I talk to are saying that replacing the seals is just a temporary fix and rebuilding them is a serious pain. I've noticed that it's quite common with large tires for the steering boxes to start leaking after a while.
My question is if I get a new one, will it only last a year or two? I've got 33x12.50's. If so, is there an aftermarket one that will take the abuse of the larger tires?
All suggestions appreciated,
Dave
84 Suburban Silverado 4X4, 4" lift, flowmaster exhaust
Marine Corps vet -- SEMPER FI
Rice Haters Club Member #75
DRASTiK is offline   Reply With Quote
Old 03-16-2003, 02:41 PM   #2
TX_Mudder
I assume you are talking about the gear box itself, which bolts to the frame.
The aftermarket gear boxes like AGR are way overpriced.
Yes you can reseal the box. I have not done it but those who have said it is not a bad job to do.
If you get a rebuilt box (or rebuild it yourself properly) and make sure to use PS fluid not ATF, then it should not leak with 33's or 44's.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 03-16-2003, 04:52 PM   #3
DRASTiK
Converted Ford guy
so what you're saying is that a new or rebuilt replacement shouldn't have a problem leaking later down the road with the larger tires as long as it's properly built using power steering fluid only. right?
Old 03-16-2003, 11:12 PM   #4
TX_Mudder
Yes, that's what I'm saying.
-- Mike
