Old 02-16-2011, 07:53 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I need to tow my truck..help
Just like it says it looks like I'm going to be working away from home alot this summer and I want to tow my 70 (with some fuel and a spare for the big truck) behind it...100 mile max
I'm woundering
how it going to effect the trans??
what the best method?? (my big truck has a pintle hook set up but I think I may add a box so I can slide in a drop ball too)
Hottrucks is offline   Reply With Quote
Old 02-16-2011, 07:55 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: I need to tow my truck..help
Put it on a trailer, or a tow bar works allright also. If you have an auto trans, i would dis- connect the drive shaft if towing.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-16-2011, 07:55 PM   #3
kaycee
kaycee's Avatar
If it's an automatic pull the driveline out then tow all you want,If it's a 4 speed you don't HAVE to but I would.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-16-2011, 11:09 PM   #4
dccarpenter
Like the other's said, disconnect the driveshaft from the rear axle , just bungee it to the frame..remember to put a piece of tape over the caps on the u-joint(or you'll lose them like I did..) and use a towbar, they work great.
dccarpenter is offline   Reply With Quote
Old 02-16-2011, 11:16 PM   #5
CG
BlahBlahBlah
You can borrow my trailer, you just have to come get it =)
Old 02-17-2011, 07:01 AM   #6
Hottrucks
Hottrucks's Avatar
I was afraid you guys where going to say that...
Pulling the DS is out of the question..I was hoping to just drag and drop since when I'm unhooking it it will be early AM when I get out of work I don't have time to fool around putting it back in then finding a hotel to stay....as far as the trailer it maybe an option but 1 I need a trailer ( mine is enclosed) 2 where do I put it when I get to the job and not worry about it disappearing??
