02-16-2011, 10:38 PM | #1 |
How do these fit and what do they actually do
I need to know if anyone knows what these do and which way they go in the exhaust pipes? I have new gaskets on the the way they seem to fit but I am undecided on how they work. I have stock manifolds. The one has a smaller hole than the other one. Motor is a 350 4bl 350 auto. Mods please move if I posted in the wrong area. I am hoping more people here would know.
02-16-2011, 10:54 PM | #2 |
Re: How do these fit and what do they actually do
Those are donut gaskets and they help seal your exhaust pipe to the manifold. It looks like your are mounted on some tyoe of guides to keep them lined up properly. I've never seen those before. Usually they just fit in between the manifold and pipe.
-Scott- |
02-16-2011, 11:10 PM | #3 |
Those are to prevent from burning out the donut gaskets so easily. They fit between the manifold and the first pipe. Help preventing leaks at the manifold. Pretty self explanatory on intallation they only fit one way with the gasket on it..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
02-16-2011, 11:13 PM | #4 |
well, self explanatory but they are different. Which side does which one go? I was guessing the one with the smaller hole goes on the drivers side? They both fit into the exhaust the same way. Either could go on either side. I want to make sure I put the one with the smaller hole on the correct side
02-16-2011, 11:27 PM | #5 |
Hand Crafted C-10
IMHO, the one on the right looks like the fitting for a stock ramhorn manifold.
The one on the left is someone elses guess. They, if you have the stock ramhorns (I assume on a '68 SBC V-8), they should both be the same, size and fitting wise.. |
02-16-2011, 11:31 PM | #6 |
Those can be made at a exhaust shop. Both should be the same identical in size. My guess is the one is a shop's custom version poorly done.
02-17-2011, 07:45 AM | #7 |
Old member
The right one looks factory. The left looks like a home made one out of a piece of exhaust pipe to fit.
02-17-2011, 10:25 AM | #8 |
I'd cut the one on the left down to eliminate the reduction. Not sure what that's all about but what good comes from restricting exhaust flow?
02-17-2011, 08:16 PM | #9 |
I think I am going to cut the tapered end off and just go with them as u suggested Special-K.
