Old 02-17-2011, 11:42 AM   #1
54 jimmy
54 jimmy's Avatar
tbi fuel injection
i'm thinking of putting a 88 tbi motor in my 54 gmc but want to know how hard it is to re-use the factory wiring. any thought on this would be great. i have the motor,computer,and wiring harness. wiring diagrams or any help.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 02-17-2011, 11:48 AM   #2
dewey777
dewey777's Avatar
Re: tbi fuel injection
I am installing TBI as well. I have heard that the 90 suburban is the best to use as the computer is pretty well stand alone. There are a few wires that can be removed from the harness. I bought a complete TBI from another member on this forum and he removed the non required wires from the harness while still in the vehicle. He could then continually test run the engine while he removed wires - SMART!
Or you can ditch the factory wiring harness and buy a painless.....
1959 Chev Apache 3100 Short Fleet Big Window
dewey777 is offline   Reply With Quote
Old 02-17-2011, 12:33 PM   #3
smittster
I used the engine from an 85 corvette and used a wiring harness from TheDetailZone.com
and it is working fine.
smittster is offline   Reply With Quote
Old 02-17-2011, 01:25 PM   #4
54 jimmy
54 jimmy's Avatar
i don't want to buy a harness as i have this complete setup and would like to make the factory harness work. if i can't use the factory harness then i will stay with my current motor. i have no funds for buying a harness and the wife says i can't buy one so that is it in a nut shell.
Old 02-17-2011, 02:30 PM   #5
chev3600
chev3600's Avatar
As long as you have the harness with the firewall passthrough and everything, hooking it up is really easy. Running the gm column makes it even easier because you have the key cylinder. I'm using a stock gm headlight switch even. Little to no mods. The computer only needs a power and ground at that point.
Thinning the wiring harness is much less fun, and not completely necessary. The ECM will need to be tuned to eliminate the emissions stuff, then.
Also consider how or what gauges you want to run. And the lockup for the torque converter.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 02-17-2011, 02:40 PM   #6
54 jimmy
54 jimmy's Avatar
i would like to make the harness a stand alone. so yes i want to thin the wires. i bought a ez wiring harness to run my carb motor and would like to use this harness with the factory tbi but stand alone. the 88 doesn't have a lock up converter. so i don't have to worry about that. as far a gauges i am running sunpro mechanical ones. my motor doesn't have a polution pump or that odd junk. i don't care if i have to leave the charcole canester or the egr that doesn't bother me. i want to do a easy simple cheap tbi swap.
Old 02-17-2011, 08:08 PM   #7
Thadious
I started with a 91 S10 harness and thought the same thing... then opted for a used Painless a guy here was selling. If I knew you were looking, I could have made a diagram of the colors you need to run it and you could have thinned it. I have two harnesses now... one for engine controls, one for chassis... and it makes things alot easier to troubleshoot.
I understand your point though and a drawing of a properly chopped harness would be invaluable to the boards.... something I'll look at when I pull mine apart for paint!
Making a stand alone engine harness from a regular TBI harness would be easy if you knew which wires needed to stay! There's only a couple of fuses in the painless one and a couple of relays... it's not really that hard.
I'm running an 88 350 TBI in mine as well...
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 02-17-2011, 08:11 PM   #8
RootBeer 6117
RootBeer 6117's Avatar
54
At school we have a 95 350 TBI setting on an engine stand, the students wired it up and we run it,some times I bug it and they have to find the problem.I used the wiring harness from a 94 chevy truck I had all the harness dash column etc. I think it it is easy to do but I did a 87 tbi in an 81 Chevy 10 yrs ago . If you need help with wiring diagrams or questions I'll be gald to help.
Joe
RootBeer 6117 is offline   Reply With Quote
Old 02-17-2011, 10:26 PM   #9
54 jimmy
54 jimmy's Avatar
thanks Thadious and RootBeer 6117. i could use a diagram that tells me what wires do what so i cam make that determination when the time comes to start this. the motor,wiring,and computer are still in the truck that i am going to get them out of. that won't happen till it gets warmer but it is good to know that i can make the motor stand alone from the rest of the truck.
Old 02-17-2011, 11:13 PM   #10
BlueJeep
BlueJeep's Avatar
It's really pretty easy. There is a large bundle of wires that goes off to the passenger side, these mainly go to the ECM. The other plug near the ECM (and white DRAC module) is the wires that go to the dash, so check engine light, brake input for TC, ALDL connector, A/C input, etc. Take as much of that wiring after the plug as you can get to, and cut it off. Also cut off the ALDL connector with as much wire as you can get with it. That's all you need from the inside unless you're going to take other stuff. On the firewall block side, unhook the block from the firewall and then you're good. Once the wiring is on the bench you can sort those out, but those are mainly power to coil, power to starter solenoid, gauge wires, and your hot all the time and the ignition hot wires to the ECM and sensors. To get it to run, really you just need to hook up the grounds, the oranges to hot all the time and the pink wires to ignition hot. I usually use the original engine wires for the coil, starter, and alternator because they're already tucked up in the loom for me, and I splice them at the firewall. Remember to fuse everything, and if you have the 1227747 ECM you don't need to do any programming for the emissions if you can live without the check engine light being hooked up...but it's always nice to have that stuff turned off if budget allows.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-18-2011, 12:03 AM   #11
jimig1
jimig1's Avatar
I have the pin out in a 1987 Light duty truck wiring diagram booklet from GM. My scanner is not working atm. I will try and work on it and get a scan of it this weekend
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 02-18-2011, 12:27 AM   #12
RootBeer 6117
I wasn't going to send it this way but I cant PM you the pictures if this doesn't work I might have to email you through my regular mail. You can save these to your pictures and then you can enlarge them easier
Joe
Old 02-19-2011, 07:10 PM   #13
54 jimmy
54 jimmy's Avatar
any body have a pic of a tbi engine in there ad just to get a feel for how it will look.
Old 02-20-2011, 05:09 PM   #14
BlueJeep
BlueJeep's Avatar
It'll pretty much look like a carb'ed motor, with just a few more wires and such on the intake....but it'll run much better than a carb'ed motor.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-21-2011, 03:11 PM   #15
mocajoes
mocajoes's Avatar
Joe
Rootbeer I am doing a similar project. 94 5.7 tbi into a 70 swb 4x4 can I get you to email those schematics to me they are to blury to print off of your post, thanks mocajoes@yahoo.com
mocajoes is offline   Reply With Quote
Old 02-21-2011, 03:43 PM   #16
Jonboy
Slots go on anything!
I did the TBI swap into my '74, and it seems to run great (I finished the swap a couple of days before taking it to Vintage air, so it hasn't been driven much). I used the harness from www.fuelinjectionconnection.com as I didn't want to take a chance on 25 year old wiring. The harness was $245, and it was stand alone. There are just a few wires to hook up, and then swapping out fuel lines.
There is a lot of good info on www.binderplanet.com also. A lot of people on there are adapting the GM TBI for use on their IH engines, so there is a lot of info on how to make it work, cleaning up the harness, etc.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-21-2011, 04:06 PM   #17
mocajoes
mocajoes's Avatar
JonBOY
what year was your tbi? did you use the factory computer?
Old 02-21-2011, 04:25 PM   #18
Jonboy
My truck is a '74, but the engine/trans/TBI was from an '87. I used the '87 ECM. I got the long block + all of the accessories, TBI, etc in a box, so I kind of pieced it together with some other parts I had laying around. It came with a TBI spacer, a fuel pressure gauge mounted in the fuel inlet, etc. Since my truck is a '74, I was able to use a factory '87 tank, but an inline fuel pump should do just fine for a TBI setup. There isn't really any need to reinvent the wheel there, all you need is fuel in and a return to the tank. The FIC harness doesn't support any of the emissions, so I eliminated it as well. Here is a link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=433689 and a TBI swap thread: http://67-72chevytrucks.com/vboard/s...d.php?t=317519 . Lots of good info in the TBI swap thread, maybe not as much in my build thread. Hope that helps. There is a lot of good info in the 88-98 section too.
Old 02-21-2011, 04:40 PM   #19
RootBeer 6117
They are sent,I sent the ones for the engine controls if you more off the truck let me know.
Joe
Old 02-22-2011, 02:59 PM   #20
mocajoes
mocajoes's Avatar
Thanks Joe.
Old 02-22-2011, 11:04 PM   #21
WB72
Before and After
WB72's Avatar
I was so happy to see this post, I am in the same decision.
Rootbeer, Would you be so kind as to send me those schematics as well.wbuchak@telus.net
Thanks Joe.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
