Old 03-16-2003, 09:04 AM   #1
70cst
70cst's Avatar
Cool Any Source for Aftermarket Cruise?
I was wondering...Are there aftermarket cruise controls that would work on our trucks? I guess I need to look at JC Whitney's.
Sometimes I need extra restraint when just cruising down the road. Know what I mean?
70cst is offline   Reply With Quote
Old 03-16-2003, 01:20 PM   #2
krazy_texan
krazy_texan's Avatar
i had an aftermarket cruise from jc whitney on my 65, worked out pretty good
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-16-2003, 01:36 PM   #3
mrein3
mrein3's Avatar
I have the Audiovox CCS-100 Cruise Control that I purchased from JC Whitney. I've had it for a good two years. The installation was easy and the system works good.
If you have a manual tranny you don't need to put the magnet on the driveshaft - the system can use a signal from the distributer. I was planning on an automatic transmission swap when I bought my cruise so I put the magnet on the driveshaft right away . Before and after the transmission swap the cruise worked as advertised.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-16-2003, 01:48 PM   #4
70cst
70cst's Avatar
Thanks for the feedback...Its appreciated!!
Old 03-16-2003, 02:26 PM   #5
lazygaurd
I have an aftermarket cruise set up in the box. It has never been opened and is complete. It was purchased from a parts (schucks or something like that) I will never use it so if someone wants it. $40.00.
I also have the dana aftermarket cruise set up from my 72 Jimmy, but not sure if it is complete. The tags say Dana (perfect circle speedostat) I don't want it either. $40.00
lazygaurd is offline   Reply With Quote
Old 05-09-2003, 01:17 AM   #6
KEH
Better late than never
KEH's Avatar
QUOTE]I have an aftermarket cruise set up in the box. It has never been opened and is complete. It was purchased from a parts (schucks or something like that) I will never use it so if someone wants it. $40.00. [/QUOTE]
lazygaurd,
Just wondering if you still have this for sale? BTW, your PM box is full.
Thanks,
Ken
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 05-09-2003, 02:56 AM   #7
lazygaurd
cruise
Yes I still have both cruise set ups for sale. I have an aftermarket unit from schucks or whatever, I have a dealer installed dana cruise unit that came out of my 72 Jimmy, and I also have a factory 1968 original cruise unit that still works, currently in the truck and listed on the glovebox door. All are for sale!!
Old 05-09-2003, 10:19 AM   #8
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
Re: cruise
I bet that was one rare opition in '68. I didn't even realize that GM put the cruise control opition on our trucks until 69 or 70.
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-09-2003, 11:49 AM   #9
Rod
Im still interesteted in your cruise lazyguard... check you PM's.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-09-2003, 12:02 PM   #10
StingRay
StingRay's Avatar
I've installed Rostra cruise controls and they have been excellent. It's been a couple of years but I think they are still around.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-09-2003, 10:41 PM   #11
oldsub86
Wouldn't it be fairly easy to put in a cruise setup from a later vehicle? You would need to put the switches somewhere other than the steering wheel but I wouldn't think the rest should be hard to install.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 05-09-2003, 10:45 PM   #12
Piston
Piston's Avatar
any mid 70-80's cars or trucks would do. grab the Transducer and the vacuum actuator then just wire in your switchs (engaging switch and brake switch) and your set. You'd also need to make/buy speedo cables.
Piston is offline   Reply With Quote
Old 05-10-2003, 12:08 AM   #13
GMC Jim
GMC Jim's Avatar
GM cruise controls (Cruise-Master speed control system) have the engagement switch mounted at the end of the directional signal lever. Rostra makes a cruise control that uses the same method ( replacing the directional signal lever)..... So, if you wish to install a cruise control very similar to the GM unit; use a model that uses the direct signal lever engagement .
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 05-30-2003, 12:36 AM   #14
wHATANERD
wHATANERD's Avatar
I pulled everything from an early 80's Olds at the Junk Yard for 25 bucks, works great, and looks stock
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
