Old 03-16-2003, 09:33 AM   #1
ScottH
ScottH's Avatar
Front end differences 78 vs 72
Can anyone tell me the differences between the front suspension from a 78 vs a 72 truck (aframes, rotors, etc.)? Also are the steering boxes interchangeable?
Any info is appreciated. Thanks
ScottH is offline   Reply With Quote
Old 03-16-2003, 11:01 PM   #2
ScottH
ScottH's Avatar
Anyone?
Old 03-17-2003, 01:17 AM   #3
pugs
pugs's Avatar
72 is abit different but my brother had a 72 and we replaced the calipers for a 73 and had no problems
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 03-17-2003, 02:52 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The disc brake versions of the '72s should almost be identical. Ask the 67-72 guys. Those guys call tell you for sure. Most of the older 67-71s can be converter to disc brakes from 72 or 73-87 model trucks.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-17-2003, 11:17 PM   #5
73stepside
73stepside's Avatar
73-87s have different tie rod ends and ball joints. other than that, if the discs are 1.25 than they will work on 71-72 the calipers should be the same for 1.25 discs too. you can make a 73-87 crossmember work on 67-72 and only have to drill 2 holes. track width is the same i believe.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
