Old 03-16-2003, 10:10 AM   #1
Marks 85
Color By Krylon
Marks 85's Avatar
Edelbrock Performer... NOT!!!
I just bought an edelbrock carb and I cant figure out the secondaries, they will not kick in. I can do it manually, but no dice going doun the road. can anyone give me a hint? thanks in advance...
Marks 85 is offline   Reply With Quote
Old 03-16-2003, 11:44 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Are you using the old cable for a Q-jet? If so that's your problem. They won't kick in because of the long cable binding up. I had to get universal cable and still need to get a new throttle bracket for mine. The new cable helps to get your scondaries working but a stock bracket doesn't work either too well. It misaligns the cable.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-17-2003, 01:16 AM   #3
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
how do you know they are not working? unless you really rev the snot out of the motor in neutral, they wont open.
when driving you can feel the throttle get to the point where it opens the secondaries (pedal gets harder) at around 50 to 75% throttle...
give more info
mike
mike reeh is offline   Reply With Quote
Old 03-17-2003, 05:16 AM   #4
twistedmetal
Take it to the limit
twistedmetal's Avatar
If you are using a stock gm intake,and bolting this carb down with the thin gasket the secondarys hit the intake when they are a quarter way open,pull all 4 holdown bolts out ,push throttle open and you should see the carb lift up off the manifold,thus meaning you need the adapter plate or an edelbrobk intake.The above is true also about the brackets,i had to go to the speed shop and get a universal chrome set.Providing you have the carter Afb style carb,if that doesn't help this site will help you setup your new carb.hope this helps ya. http://www.carbs.net click carb information key,then scoll down and click on weber carburator adjustments.
This is the whole wealth of knowledge i can offer you,i had lots of problems with mine.
"If Fall Guy only knew how many trucks i wrecked,He'd be proud"
E-Mail me personally @ jaggededge_6969@yahoo.com if anything seems foggy to you.
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
