I have a 85 Chevy swb, fleetside with a 4.3 V-6 in it. I am looking at replacing it with a mild 350 w/ a turbo 400 transmission. Question is, if I use a 350 or a 400 turbo which tail shaft transmission do I get, long or short? HELP!!!!!
------------------ 68 GMC short fleetside/406 sb./400turbo w/shift kitand 2500 stall/3:73 posi./ps/pdb/ac/front sway bar/15x8 rallys/"PORSCHE RED" w/ black tuck-n-rolled interior. 86 Chevy short fleetside
68 GMC short fleetside / 350 LT! sb. / 350turbo w/shift kitand / 3:73 posi./ps/pdb/ac/front sway bar/15x8 rallys/"PORSCHE RED" w/ black tuck-n-rolled interior. 86 Chevy short fleetside w/ 406sb /400turbo w/ shift kit 2500 stall / cowl hood |
BAD BOW-Silverado XST
WOLFMAN,
The answer depends on the tranny you have now. If it's a 700R4 then get the long 350th tailshaft. I'm not sure about the 400TH. If you have a manual tranmissions you may need matching driveshaft for either transmission. I'm sure someone else will able to answer your question on the 400th. ------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" |
