Old 02-17-2011, 09:46 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Those with factory tachs... check in!
I'm looking to see if someone can post a picture of where the tach wire comes through the firewall. I'm trying to determine which dimple is the 'correct' dimple as there are 4 to pick from depending on the options installed.
I "think" it's the 3rd from the bottom, but I want to make sure I'm selecting the correct one. Working on a project for my FIL.
Please post a picture of your firewall.
Thanks in advance guys!
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-17-2011, 10:59 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Those with factory tachs... check in!
Bump for ya~~ or should I say 'dimple'?
ETsC10 is offline   Reply With Quote
Old 02-17-2011, 11:51 PM   #3
firedog
firedog's Avatar
Speaking of the fil where are the pixs of his truck?
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-18-2011, 11:56 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
bttt...
I have seen this thread, but I want to locate the exact dimple that would have been utilized for the tach wrie.
http://www.67-72chevytrucks.com/vboa...+wire+firewall
Is this the correct dimple???
More to come.
-Nate
Old 02-18-2011, 12:26 PM   #5
smorg007
smorg007's Avatar
My dimple where I drilled my tach hole was exactly where the picture shows it to be. Not quite as deep as those in the picture. I used the dimple as a punch hole for the 3/4 bit. There was even a perforated hole in my firewall material to match this location.
smorg007 is offline   Reply With Quote
Old 02-18-2011, 07:30 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the post.
What did you mean by 'not quite as deep?'
-Nate
Old 02-20-2011, 02:32 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Nate,... I posted in this thread,...
http://www.67-72chevytrucks.com/vboa...ad.php?t=43277
I should have posted here.
Lot's of confusion on where the "original location" of the tach wire hole should be in the firewall.
Since the 67-68 firewalls are different,... you have to address the 69-72 trucks only.
I don't have a picture out of the assembly manual.
Maybe someone else can reply.
Keith
Convert to disc brakes.
Old 02-20-2011, 04:26 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Bttt... Anyone?
Bueller,... Bueller?
-Nate
Old 02-20-2011, 04:49 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Re: tach wire ?
Here are two different ones. the first one is a '67-'68 six cyl and i think one of the cables shown is for a cable driven tach. The second one is '71 six & V-8.
LockDoc
Leon
Old 02-21-2011, 02:40 AM   #10
VA72C10
VA72C10
VA72C10's Avatar
Great info!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-21-2011, 05:22 AM   #11
steelscout
Words under my name
steelscout's Avatar
subscribed, good info in this!
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 02-22-2011, 10:22 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Hey Leon... you don't by chance have UPC-1's diameter as it refers to the bottom of the picture posted above? Hole Dimensioning...
-Nate
Old 02-22-2011, 10:30 PM   #13
tcb-1
Nothing to see here.....
tcb-1's Avatar
take it back what I said a few nights ago. I used the dimple that's opposite of the 1-5/8 mark on the ruler. I looked at several factory tach rigs before I drilled at that location. forgot what size I drilled though. I believe I drilled a full size less than the grommet on the harness.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
