![]() Join Date: Jun 2010
Can I run motor with no driveshaft installed?
I'm working on getting the motor on my truck running. Can I run it without a driveshaft without trans fluid leaking all over the floor?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Can I run motor with no driveshaft installed?
Yes.
You might jack the rear of the truck up a bit so no fluid comes out of the back of the trans though. Sometimes if the fluid level is high enough, some will drizzle out. If you put the back of the truck about a foot higher than the front you'll be covered either way.
this is good to know mem and my dad plan on starting my truck but not driving it and i dont have a driveline so it will be started without a drive shaft...
I have a plastic plug I put in the rear of mine. I've never ran it with it in though. I use an old yoke as I have several. They may still sell the plugs at most auto parts stores but I haven't checked. I wouldn't trust it to leak without something plugged
I was going to put it in gear as well and see how the transmission sounds.
looks like great minds think alike!
You can start it with no driveshaft, but I wouldn't put it in gear with the engine running with out the driveshaft. Without the yolk there is nothing supporting the output shaft of the transmission, it will move all over the place and could possibly damage the trans.
Good info, thanks! That's the kind of thing I want to avoid. No point running the transmission to find out if it's any good and then destroying it by being dumb!
Then it will fly off and wreck the bottom of your truck AND the transmission.
