Stalker Nate
68 Chevy Rad support same as 72 Chevy?
Are they identical in how the front end bolts up or are they completely different?
I know the difference in the frontend, but I'm curious to know if there's much difference in the rad supports or if a '68 support can be used on a '72. Thanks, Nate
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
Re: 68 Chevy Rad support same as 72 Chevy?
I'm pretty sure they are different. The headlight buckets are different, I believe.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
According to the aftermarket, 67-68 are the same. 69-72 are as well. Not sure what the differences are but they do appear to be different for some reason
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
Stalker Nate
Well I figured they are different due to the fenders, but I'm curious to know what the 'real' differences are. I think the frame mounting is slightly different as well. There's not much difference between a '68 & '72 chevy grill/headlights. I have both trucks, but without taking everything apart I can't tell if there are any major differences.
Watch out for your cornhole !
![]() Join Date: Jun 2003
There are significant difference is the headlight mounting. It will be plain to see when you look at both of them side by side.
![]() Join Date: Jan 2011
The bushings where the core support mounts to the frame rails are also different. 67-68 vs. 69-72.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Similar but different question...
Is a 67-68 GMC rad support the same as a Chevy? ie. could you use the chevy grill and just ignore the additional (inside) headlight buckets? |
i switched mine from 70 and put 67-68 front end on it and yes they are different and they have two styles of bushings to mount to the frame. i ordered them for the core support but you have to have them for whatever frame is under your truck
#9 | |
VA72C10
![]() Join Date: Mar 2008
As mentioned the buckets are different on 67-68 vs 69-72...and the bottom holes are a different size to work with the different mounts.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
