Old 02-18-2011, 12:44 AM   #1
Blue Heeler
Blue Heeler's Avatar
Help lowering the Blue Heeler
Hey guys, after waiting a month on a lowering kit i was wondering when tearing apart the front-end do i need ball joint tools to tear down a-arms or is it just a set screw and a spring compressor that i need? this is for a 65
c-10. thanks.
Blue Heeler is offline   Reply With Quote
Old 02-18-2011, 12:54 AM   #2
erock805
erock805's Avatar
Re: Help lowering the Blue Heeler
You will be safer if you did use a spring compressor if you have never done anything like this...Yet On these trucks I never used one. As I recal, if you are doing the ball joints you have to cutt the rivits off (unless they have already been replaced) then just take the bolts off. NOt too tough, just got to work through it.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 02-18-2011, 01:10 AM   #3
jimmydean
jimmydean's Avatar
If you have a grinder or air chisel to remove the top rivets, then rent a ball joint press for the lowers. Not a bad idea to replace your tie rod ends and get everything new, then get it aligned once it's all together.
I've never used a spring compressor on these, but it's not a bad idea. Just be careful, there is a good how to about it on here, I'm sure there are plenty of threads with pictures, too. It's basically the same process for all years.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-18-2011, 02:15 AM   #4
chopper john
chopper john's Avatar
lossen the nuts on the spindle and with a small mallot you hit the part on the spindle where the ball joint goes through, they should pop out . once they pop get a floor jack and take the tension off the nuts and remove , drop the controlarm. im thinking your doing spindle and spring ?
chopper john is offline   Reply With Quote
Old 02-18-2011, 08:51 PM   #5
Blue Heeler
I was not planning on changing the ball-joints but since i'm in there i might as well
thanks for the help guys will take pictures but still having trouble posting. it shows me something like http b*llsh#t this and that.
Old 02-18-2011, 10:21 PM   #6
jocko
jocko's Avatar
I'm with chopper john - this is the way I do it. Have used a spring compressor in the past but found this (chopper john way, not the spring compressor way) to be the best and safest way. The key is to have the floor jack under the lower control arm just barely touching - that way it allows the spring pressure to help pop the spindle loose but also keeps it from flying across the garage. Once it's loose, then just lower the jack handle SLOWLY...
Good luck.
Old 02-19-2011, 03:15 AM   #7
old cruiser
old cruiser's Avatar
Good luck.
You may want to undo 1 shocker mount just makes life a little easier to let control drop further, but yes jack just under arm is the way to go.
old cruiser is offline   Reply With Quote
Old 02-19-2011, 12:23 PM   #8
jocko
jocko's Avatar
Hey Blue Heeler, do you have a Blue Heeler? I gotta ask!
Old 02-19-2011, 10:32 PM   #9
chopper john
hey blue heeler. if your truck runs and you dont mind driving to anaheim, then i dont mind giving you a hand with this . fairly simple . i was also saying without changing the ball joints . no special tools.just a floor jack and a nice mallot. i have the tools at home.
Old 02-20-2011, 11:44 AM   #10
Blue Heeler
Sure do. this guy is a nut. you gotta keep him busy.
Old 02-20-2011, 11:56 AM   #11
Blue Heeler
Chopper john thanks for the invite. went to my buddies tire shop yesterday and used his lift.and just started going at it with a couple of friends. started at 8am and finished about
2:30 did springs, shocks, idler arm. just a little sore from snapping bolts feeling like a circus clown.. looks much better. i dont think i'll go much lower
because my welding machine weights about 600lbs but i will fab up brackets for some helper bags. i still running stock rims but cant wait to put my old skool rallys with flat caps. Thanks everyone on your help, i'm sure i'll be asking again. now i just need to figure how to upload some pictures.
Old 02-21-2011, 03:44 PM   #12
chopper john
are you going to the cpp truck show ?
Old 02-21-2011, 09:49 PM   #13
Blue Heeler
Hell yeah im going!! sprung a radiator leak from the upper hose yesterday and fix that!! now another leak from radiator. screw it i'm ordering new water pump,lower hose and radiator. I seen something bout everyone meeting up somewhere and cruising to the shop keep me posted.. i'll have a 30pk of coorlight in the back of my truck if anyone would like a cold one. haha
