Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-18-2011, 02:13 PM   #1
tech@scottshotrods
Why Settle For Second Best
Right Now at Scotts Hot Rods We are offering a Special On Ridetech Control Systems the Premier manufacture for all your Air Suspension Needs...
We are offering free shipping and a special forum discount on All Air Ride Control Systems! Call (805) 485-0382, PM or Email me at jonm@scottshotrods.com
Unlike other comperable systems on the market the E3 offers height and pressure readings which is important when trying to achieve proper rate and height imediately, as well as a visible read out that offers error codes and a menu driven display that you can understand and read.
Most importantly INSTOCK and ready for imediate shipping
Air Ride/ Ridetechs new RidePRO e3 system controls your suspension with accuracy, repeatability, versatility, dependability, visibility and a wide range of other abilities to give you unparalleled levels of control - all at the push of a button.
ALL NEW CONTROL PANEL - Building on the experiences of previous systems, the new RidePRO e3 represents a leap forward in onboard suspension controls, starting with a completely new control panel that is sleeker and brighter. The auto-dimming transfl ective display is completely visible in the sun and is only 3/8” thick. Interface buttons are backlit and have a distinct “click” to let the driver feel when he has made a change. Two mini USB connections are offered to allow a variety of panel mounting and connection options.
ALL NEW ELECTRONIC CONTROL UNIT - The new e3 ECU is faster, more robust, and offers more options to refi ne your air suspension. In addition to the 3 ride height presets and the “ride height on start” feature, the calibration process, weight compensation, and crossload compensation are now all automatic. If a problem should arise , error detection and troubleshooting menus have been added into the unit to make finding and fixing problems much easier.
The new e3 ECU uses M12 twist connections and is now waterproof to allow mounting in any location on the vehicle. Solid state compressor relays are built in to eliminate external relays and wiring. The LevelPro e3 leveling system is compatible with any air suspension and is a great upgrade to your current system.
tech@scottshotrods is offline
Closed Thread
