Has more rust than truck...
Manifold problem
Slight problem with my factory exhaust manifolds. They hit my motor stands. I am using my stock 6 cyl engine stands with adapter plates. The manifolds hit the stans on both sides. What will fit? Headers are out of my budget. F body, TBSS? Thanks
![]() Join Date: Dec 2008
Re: Manifold problem
tbss fit with no problems
I hope so, I'm trying to sign up on TBSS owners to buy some now.
Green club
I was going to look for some SS manifolds as well, my pass side truck manifold hits the perch and the flange rubs the frame.
They are are kind of hard to come by from where I am brousing around, uness you buy new ones which I think Dorman makes too. They are over $150 each though, I wonder if I can use just the pass side and use the truck manifold for the drivers? Humm.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
I found mine on ebay by searching for "v8 blazer manifold" paid about 125 dollars a pair shipped.
Just got some on TBSSowners for $60 shipped. There is another set on there for $70 Shipped if anyone needs them.
Green club
Want them, I will register over there and see if they are still available.
Registered, there are a few sets for sale still, thanks for the heads up USMC!
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 02-22-2011 at 01:51 PM. |
Bad news, Got the TBSS manifolds today......no go. They still hit the frame stand. A little bit closer, but still not going to bolt in.
Pics taken with bolt in rear most manifold hole. ![]() ![]() ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
you are using stock motor perches right?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Yep, stock 6 cyl stands. Right now I'm trying to decide if I can make enough clearance with grinding both the manifold and the stand or if I should just buy some POL tubular stands.
I should have stated before that I used the '73-up perches and mounts. They don't bolt in but was an easy mod for the height difference in frame rails of the 67-72 and 73-87. I had to use the tbss manifolds and the 73-87 motor mounts. I apologize for not providing all the information.
All good man. I just need to figure this out, maybe the 73+ mounts will work for me.
#13 |
Truck and auto performance nut
those manifolds are pretty thick....doesn't look like you need much off of them?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#14 |
I used 6 Cylinder Stands originally, I couldnt get Truck Manifolds, or F body manifolds to fit at all without cutting and griding on the engine stands. I've since removed them for v8 stands because I didnt like how far back the motor sits with the 6 cylinder stands.
