Old 02-19-2011, 12:42 AM   #1
weldvair@embarqmail.
eliminating R&P twitchiness
My trk really steers nice...all the twitchiness is gone from the T-bird
R&P.
I used a Borgeson flow reduction valve in the chevy pump &
added 4 washers to the the pressure valve. It now runs at
800psi vs 1100.
gives a relaxed drive........Don
weldvair@embarqmail. is offline   Reply With Quote
Old 02-21-2011, 06:30 PM   #2
BigJock
Re: eliminating R&P twitchiness
Just made the same mod to mine,although i've still to try it out.
My buddy's 52 with R&P was a real bear to drive until he made this cheap modification.
Worth every cent.
BigJock is offline   Reply With Quote
Old 02-22-2011, 04:24 AM   #3
slimneverdies
slimneverdies's Avatar
You have any pics of this setup... I'm going to have to do this on both of my trucks
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 02-22-2011, 09:31 AM   #4
All the mods are inside the GM pump so they can not be seen. Do a google search for "GM ps pump pressure reduction" & you will get info.
In addition to the mods you MUST set your caster to 3 1/2 degrees, not
factory specs for a Must II.
Don
Old 02-22-2011, 01:06 PM   #5
cajundragger
mine is at like 5* with the same mods. I like my wheel to fly back to center though.
cajundragger is offline   Reply With Quote
Old 02-22-2011, 05:21 PM   #6
Atomsplitter
Atomsplitter's Avatar
The kit is Borgeson p/n 899001 and they sell for about $18.
Each shim reduces the output pressure by 100psi and its as easy as unscrewing the fitting (valve) that the discharge line connects to at the back of the pump. Disassemble the fitting and install the desired number of shims, reassemble and test drive.
Jegs, Summit, etc all sell these kits.
Up here in Ontario you can get them through Hortons Hot Rods.
Atomsplitter is offline   Reply With Quote
Old 02-22-2011, 10:11 PM   #7
slimneverdies
Maybe this is a dumb question but will this kit work on both a 305 and ls2 pump?
Long live SLIM
Old 02-22-2011, 11:12 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
If your running hydraboost and a Ford rack this fix doesn't help you. You need the Heidt's pressure bypass. That way you don't loose the 1200 - 1500 psi you need for braking but maintain the 600-800 you need for a Ford Rack.
dwcsr is offline   Reply With Quote
