Carrier Bearing? CPP Billet worth it?
I see that CPP makes a billet bearing that looks very nice but are they that much better than the Autozone off the shelf one? I plan to beat my truck a little bit via a 400+ hp 406 SBC, drive on some long trips, and pull trailer and boat? i like preventative parts but id like some imput from some ppl that have used this!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Re: Carrier Bearing? CPP Billet worth it?
Carrier bearing as in the rear or center bearing in a 2pc driveshaft? Either way,what these trucks came with works fine. They have proven to be the longest lasting and most reliable trucks ever built. I'm not sure about what Autozone sells,but an OEM design part from a quality bearing company does the trick just fine.
![]() Join Date: Feb 2011
I don't know about the aftermarket one, but I replaced mine with the Autozone one last month and haven't had any problems.
1971 C20 Longhorn Custom Camper |
#4 | |
454 MAKES IT ROAR
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
I have no insight on it but im lookin at gettin one.seems to look like a great part imo.I also have no experience with the stock ones either so im not much help lol
the two piece driveshaft one!
I would like to get one. It looks like to me that it is more sturdier than the OEM or AutoZone one. I have had my truck around 13 years or so and it has allways been my daily driver. I have had to replace my carrier bearing/ center support bearing 2 times. I also had a new driveshaft built and balanced by Inland Empires. I have put on close to 14,000 miles on my truck between Febuary of last year and Febuary of this year, so yeah, I have put on some miles on my center support bearing. I usually average 8,000 to 10,000 miles a year.
![]() The problems I have encountered with the OEM or AutoZone one is the rubber part dry rots out/ tears out. I have also had the stamped metal part come unstamped. I just drilled a few holes and bolted it back together to buy me some more time 'till replacement time. So in my opinion the billet one should hold up a lot better. Keith |
Restoration Virgin!
guys...check in with vendor CPPJeff....he maybe able to get you a deal on these too
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Dave's not here, man
I've seen a few guys place some extra tac welds on metal surround the the bearing rides inside of. They've had good luck going that route. I thought about going the CPP route myself, but swapped to a one piece instead.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Amen! I did not have much luck with carrier bearings so went one-piece and haven't looked back (or underneath) since.
67 Stepside Atomic Orange Fastburn 385 TH350 The wheels are fronts are 255-45-18 with 5" bs. 18x8 wheel rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit) Budget: A method for going broke methodically. You only live once! |
I went thru 2 new stock ones within 6 months. Switched to the CPP billet one and haven't had a problem since!
Posted via Mobile Device |
Any pics of it installed?
#13 |
10/30/19
You guys that are going through carrier bearings..are your trucks lowered or factory height?
Also,where are you guys getting your one piece driveshafts..I'm wondering if your trucks are longbeds..
Fight the good fight, finish the race, keep the faith |
#14 |
I started tearing up the bearings after I lowered my truck (short bed) My exhaust guy had a driveshaft in his shop that he wasn't using that I had cut down so I was able to do the swap for less than $50.
#15 |
My SWB started tearing them out right after the 3/4 drop. Had the two piece balanced by Inland Driveline and still took one out. When I complained they showed there version of the the billet carrier, I bought it and have not had any problems in about 15K miles.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#16 |
Redefining LowBudget
I ve been though 2 from auto zone...my truck is bagged with pro street tires and a caddy so it gets some abuse...planning a 1 piece as soon as I free up some cash but having a place to get replacements NOW is always good
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#17 |
the boat guy
I sell billet carrier bearings and I wouldn't put one in my own truck! The oem style works just fine after a little beefing up on the bracket. Good ujoints, a straight and properly ballanced driveshaft and the oem style carrier should last another 40 years regardless of hp.... It takes way less than 1hp to turn the race attached to the shaft in the bearing. But hey if you want billet have at it, they last as long and transfer any vibration right to the frame.
