Old 02-19-2011, 12:03 PM   #1
kcsa75
kcsa75's Avatar
Windshield Washer Woes - What is this?
I started to trace the tubing for my windshield washer and found this device. It is hanging off the firewall near the master cylinder. The tubing from the washer jar runs to it then two tubes out to the cowl. It has two electrical connections.
Is it an external washer pump? If not, what is it?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 02-19-2011, 12:15 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Windshield Washer Woes - Was it this?
I would say it is a washer pump.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 02-19-2011, 12:45 PM   #3
Livrat
Member #1049
Livrat's Avatar
I agree, it is an aftermarket washer pump
Livrat is offline   Reply With Quote
Old 02-19-2011, 12:53 PM   #4
BlackTopMotors
yep, old aftermarket pump or came off another car...just replace it/remount a new one, replace your tubing...clean up the wiring and you should be good to go unless you want to go back to factory then that one is different and connects to your wiper motor under the dash (that likely went out and they bypassed it for the easy fix. Best of luck. Roger
BlackTopMotors is offline   Reply With Quote
Old 02-19-2011, 07:19 PM   #5
eagleuh1
eagleuh1's Avatar
I just bought a new pump at Oreilly's to go back original equipment. Its the only new part I've bought so far thats made in the USA.
eagleuh1 is offline   Reply With Quote
