02-19-2011, 01:19 PM | #1 |
Spring Time Work
O.K. guys this coming weeks in am going to turn my C20 into a C10
I need some info still. I am looking at a 1972 C10 it has front disk and a 3.73 rear. I know the front clip will bolt right up but what about the rear. I beleive from previous threads it will. Any help , I have all the tools but my rental home has limited electrical, so I really can not use my welder. |
02-19-2011, 01:26 PM | #2 |
Re: Spring Time Work
The only change will be the panard bar bolt locator, you`ll have to modify or by new....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
02-19-2011, 03:05 PM | #3 |
So, I guess I will be placing an order with CPP for the bar.
Everything else will line right up! |
02-20-2011, 02:36 AM | #4 |
If the '72 rear and yours are both trailing arms or both leafs, then you are good to go. Otherwise, you will need to modify the perches to fit the suspension you have.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-20-2011, 03:44 AM | #5 |
60-66 Nut
Yes the '72 rear end will bolt right up to your trailing arms. However, like Rich said, the panhard bars are different. The C20 used the long panhard bar with the mount on the passenger side axle tube. The '72 uses the short panhard bar with the mount on the passenger side of the center section. The longer the panhard bar, the less side to side travel through out the verticle suspension travel. If you decide to go with the shorter '65-'72 panhard bar, you will have to either put a slight bend in the bar, or change the mount on the frame.
02-27-2011, 07:36 PM | #6 |
Man I am MAD.
The seller of the parts started trying to hustle me for more cash. We agreed on a set price then when I show to pick up he wants more. I walked!! |
02-27-2011, 08:19 PM | #7 |
Happy to be here
Even though the guys needs a good smack in the head, don't despair. There are plenty of donor trucks out there.
