Old 02-19-2011, 03:15 PM   #1
Corts60
Just here to tinker
Corts60's Avatar
Do they make Suburban fuel tanks?
Hey guys, so I pulled the fuel tank and looked inside and it is miserable. The sending unit and pick up tube looked like the Titanic and there is all kinds of junk in the tank.
My question is: Does anybody make a replacement for the 60-62 burbs? If not, is there an after market tank that works? This is pretty much the last thing holding me up from driving this girl around. Thanks in advance for the help!
Old 02-20-2011, 02:37 AM   #2
sasquatch5308
sasquatch5308's Avatar
Re: Do they make Suburban fuel tanks?
Is it under the body between the rails? If so I would think a later model truck tank would work.
safety third!
1962 swb 4x4
1952 Chevy "turd bucket" truck
1953 Buick special
1953 Famous James motorcycle
1975 Scout II
sasquatch5308 is offline   Reply With Quote
Old 02-20-2011, 03:05 AM   #3
Captainfab
60-66 Nut
I don't remember how different the '60-'62 Burb tanks are from the '63-'66's, but the '69-'72 Blazer tank is nearly identicle to the '63-'66 Burb tank. Except for the half round indent for the spare tire.
If you could post up some dimensions, we can see how yours compares to the '63-'66 tank.
The bottom line is, I am not aware of anyone reproducing the '60-'62 Burb tanks.
Old 02-20-2011, 09:02 AM   #4
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Hi Cort........................I replaced my tank on my 65 with a new replacement tank from a 67-72 Blazer.....................It came with a 90 ohm sender which worked for me because I have newer gauges..............It also was a little bigger than the origional tank............Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 02-20-2011, 06:54 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
Here are pics. I couldn't find a tape measure.
Old 02-20-2011, 07:41 PM   #6
chris91
Is it worth taking to a radiator shop, or cleaning the tank with a restoration kit.
chris91 is offline   Reply With Quote
Old 02-20-2011, 08:37 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
It isn't rusty but there is a bunch of nasty stuff inside. Smells awful. From what I've read on this board, it seems to be worth just buying a new tank instead of dealing with cleaning it. I am going to call some radiator shops tomorrow and see what they charge to clean it out.
But now the question is: do they make the correct sending unit? Mine is a bolt on, 30 ohm.
Old 02-20-2011, 09:16 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
I'd reuse it; but thats me.....looks in better shape than mine was. I put a new sender in; they are available.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-21-2011, 12:35 AM   #9
Captainfab
60-66 Nut
I agree....See if you can get it cleaned out for a reasonable price. I'm not sure if the bolt on '60-'62 sending units are available from the aftermarket. I believe the aftermarket universal senders have the same bolt pattern, but the ones I've seen are 90ohm senders.
Old 02-21-2011, 11:00 AM   #10
protrash64
protrash64's Avatar
I have to update my previous post; I didnt realize the sender I used was listed for 63-66. I dont know what the difference would be as my tank looks like yours. I think I would give this a shot.....
Classic Industries # CX1844
Old 02-21-2011, 01:29 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
Hey pro-trash, if that is a bolt on, that looks exactly like the one I pulled out. I'll take a pic. Thanks for the info!
Old 02-21-2011, 02:15 PM   #12
protrash64
protrash64's Avatar
Cort.....I know the frames are different, but I find it hard to believe that the senders would be different for 60-66. Jus' sayin' Maybe if the tanks are a different depth??
I used that sender in a stock application, by the way.
Old 02-21-2011, 02:49 PM   #13
Corts60
Just here to tinker
Corts60's Avatar
OK sweet. It definitely looks like my sender. I'll go ahead and order it. Thanks again.
Old 02-22-2011, 02:05 AM   #14
Captainfab
60-66 Nut
The '60-'62 Suburban/Panel sending units are attached to the tank with ~5 screws and a flat gasket. The '63-'66 Suburban/Panel sending units are attached to the tank with the twist in lock ring with a O-ring type seal. I don't know if the depth is any different or not.
Old 02-23-2011, 08:49 AM   #15
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
my tank has some of the same issues, and it has a few deep dents.. any ideas on pushing the dents out?
Old 02-23-2011, 07:34 PM   #16
protrash64
protrash64's Avatar
I wonder if it could be drilled and fit? Gaskets are easy to make. May be the best option if nothing else is available. Would a generic sender be more hassle?
Old 02-23-2011, 08:27 PM   #17
Corts60
Just here to tinker
Corts60's Avatar
Well I called a few places today for cleaning the tank and I got prices ranging from $150-250 to clean all the varnish and sludge out. Since the tank isn't rusty, there shouldn't be the need for any repairs I would think.
What is your guys' opinion? Should I fork over the $150 to have it cleaned or go with a new tank from a later suburban or somthing? I'm still gonna have to buy the sender so with cleaning and a new sender I lookin at $200.
Old 02-23-2011, 09:19 PM   #18
protrash64
protrash64's Avatar
If it's that much, I would use a retrofit tank and avoid the hassles. Why cant you clean the tank out yourself?
Old 02-23-2011, 10:07 PM   #19
Corts60
Just here to tinker
Corts60's Avatar
There is probably 1" thick varnish on the bottom of the tank and I just don't have the resources to perform it myself. If there wasn't so much sludge I could probably do it.
Old 02-23-2011, 11:17 PM   #20
protrash64
protrash64's Avatar
Damn!!
Old 02-24-2011, 02:16 AM   #21
Captainfab
60-66 Nut
I think for that price, I would go with a new tank and sender of some sort
Old 03-11-2011, 12:31 PM   #22
Corts60
Just here to tinker
Corts60's Avatar
OK, I have posted updates on the tank and sender on my build thread but I thought I would post pics and info on the sender I am going to use here for future thread searchers. It is for the 55-59 trucks and the P/N is 47-9300. The float and pick up tube are 180 degrees out from the OG one, but I am fairly sure this will work.
