02-19-2011, 05:03 PM | #1 |
Shock relocate on 2/4 drop
Do I need to redo my shock mounts if I just go with a 2/4 drop?I saw the post on redoing the rear mounts ,I just went with cut springs on front and jeep springs in the rear.Thanks for the help
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
02-19-2011, 06:11 PM | #2 |
Re: Shock relocate on 2/4 drop
It's hard to answer 100% accurately since a 2/4 drop is possibly different from truck to truck (2/4 drop from stock, from where it was, etc...). The best way to know is to do some basic measuring & determine what your needs are. Take some measurements of shock length (eye to eye) @ ride height. Then remove them, measuring for fully compressed, & fully extended heights.
You'll get pretty decent ride quality & shock travel w/about 2-2.5" minimum travel up/down. Compare your ride height shock dimension w/the 2" min need & see what the tape measure says. Example: Lets say the hypothetical truck has.... Front shock length @ ride height = 13" Front shock fully extended = 17" Front shock fully compressed = 10" 13" + 2" = 15" for decent expansion w/o over extending & it's less than the max @ 17". 13" - 2.5" = 10.5" for decent compression w/o bottoming & there's still .500" before the shock bottoms out. With something like this, there's no need for relocating mounts or 'custom' drop shocks. The rear would be done in the same fashion.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-19-2011 at 06:11 PM. |
02-19-2011, 06:15 PM | #3 |
And once you follow Scoti's advice take that dimensional data and look at the charts that shock manufacturers supply on-line.
Here is the link to data forI was able to find off the shelf Monroe shocks for my 4/5 static dropped '65: Rear: Monro-Matic Plus P/N 32207: 17.875" Extended, 11.250" Collapsed Last edited by lakeroadster; 02-19-2011 at 06:18 PM. |
02-19-2011, 11:23 PM | #4 |
OK Thanks alot for the info ,I got the rear springs in today and it dropped it 3" will try and get the fronts done tomarrow
02-20-2011, 08:55 AM | #5 |
FYI: Typically they will drop a bit more once driven around a bit.
03-27-2011, 08:39 PM | #6 | |
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
