Actual rear-end flip
could you actually flip the rear end upside down (left drum to right side) and bolt it on top of the springs?
if you could, you wouldn't need any kind of flip-kit at all--just c-notches. i've been thinking it might work. |
Re: Actual rear-end flip
The housing for the bolts is different. you'd probably drain all your oil out cause your rearend would be upside and leaking out?
And if I'm not mistaken, you'd have 5 reverse gears and 1 drive gear if you flipped it your way. Last edited by the_duke; 02-19-2011 at 05:17 PM. |
The One And Only !!!
Simply put, It Can't be done and driven down the street....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
One day...
![]() Join Date: Apr 2008
no just buy the flip kit..
Try spinnin 4 rear tars
As The Duke said, it would go backwards. You would have to put the truck in reverse to drive it forward... So nope
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
it would go the same direction--the only thing i see that would be a problem is the pinion yoke would probably be too high.
Java Mechanic
It *would* be reversed. All of the angles would be seriously out of wack also.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Yea. Just get a flip kit..if you want to go cheap..there's a guy selling the brackets by them selves for around 40..reuse all your old hardware..used em on my 89 no probs.
Posted via Mobile Device |
Waiting for Paul to Open Safe
No the rotation of the wheels after the flip will pull the truck backwards instead of pushing the truck forward. The rotation of the driveline will not change, thus the wheels will still rotate in the original direction, flipping it will cause it to go backwards not forward.
wow, this is turning in to quite a discussion.
i'm not gonna do it but it still think that it would still go the same direction. since the rotation of the engine is not gonna change it would be just like a propeller on a wooden toy plane. it's gonna spin the same direction regardless of the position of the plane itself--be it upside down, side-ways, whatever. just think of the truck as the plane and the diff as the propeller. does this make any sense? the only thing different is the ring gear is now gonna be on the pass side instead of the drivers side. i may be wrong though--it's rare but it does happen, ha ha. |
67-72 parts collector,…
![]() Join Date: Nov 2002
I disagree with everyone.
I say try it and give us some feedback. There are alot of members that ask questions on here and don't listen to the replies. I say prove them wrong. Take plenty of pictures. We all like pictures. Cap the vent hose so all the fluid doesn't run out. Cut off and re-weld the shock mounts. I myself would just get the flip kit saddles and shock extenders and be done.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-21-2011 at 05:14 PM. |
#12 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
I drew one out on paper. The diff would be driven the same direction. I think. . Last edited by ETsC10; 02-21-2011 at 06:36 PM. |
#13 |
So..everyone got me thinking..had to "test" this..I agree..I don't think it would go forward...I grabbed a bottle..and rotated it forward..if u flip it while it's rotation..it indeed rolls backwards. Although..I did it several times. Couldn't be sure. Lol
#14 |
ha ha.
texasfunk, the bottle trick isn't a good comparison. that would be like turning the yoke around backwards. think about a truck that was driving down the road and has rolled over in a wreck. the engine and trans is gonna be upside down too but it doesn't matter because it still rotates in the same direction. now the rear end is upside down but the wheels are still gonna be turning the same direction as before it rolled over. anyway, i'm not gonna do it--just daydreaming. who has those brackets for $40? is it a board member? |
#15 | |
Old Skool Club
![]() Join Date: Jun 2001
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#16 |
you guys are right.
i figured out what texasfunk meant by spinning the bottle and flipping it--i was doing it the wrong way. i was flipping the bottle end to end, not side to side. Last edited by cris well; 02-21-2011 at 08:42 PM. |
#17 |
Lol..I was like..hmmmm...I went to the shop an had an axle laying around...had to try it again. It indeed goes backwards. Lol..now let's put that to rest! I'll see if I can find the link to the flip kit for ya
#18 |
Just reverse the rotation of the engine and you will be good to go........
![]() Posted via Mobile Device
CHEVY ONLY
#19 |
Happy to be here
![]() Join Date: Mar 2000
Even if it would work, the rear axle isn't designed to run upside down. It would burn the bearing up eventually.
#20 | |
A marine cam should cover that !
#21 |
I had to wait to say this after the discussion...
I thought I was wrong, but man, am I'm glad I'm right. :LOL: |
#22 |
#23 |
I had to think twice about it, but the wheels definitely reverse rotation. If you have a truck with a posi rearend on jack stands and drop the driveshaft, you can spin the tire on the passenger side clockwise, normal direction for forward movement. Rotate that axle 180* and direction for that tire is now still clockwise, but it's now turning towards the back of the truck...reverse.
Even if that didn't happen, you'd probably starve the pinion for lubrication, plus all your diff fluid is going to run out your vent tube. Last edited by BigBlocksRule; 02-23-2011 at 08:42 AM. |
#24 |
![]() Join Date: Jan 2010
There was an episode on Extreme 4x4 a couple of weeks ago where they did flip the rearend for a rock crawler. They did say that it would change the direction. If interested you might look it up and see if there is any recap that might explain what they did to correct everything.
78 El camino 89 GMC SWB 98 Z28 99 2dr 2wd Tahoe (sold 8/31/2012) 07 Yukon SLT 09 G8 GT |
#25 | |
Charlie Daniels w/ a Tq Wrench
As stated before,
it would rotate the wrong way would need to plug the vent and vent the plug ![]() pinion bearing would not be lubed properly. You "could" flip a 3rd member axle like a 9" or a Yota, or one of the old Eatons, and leave the 3rd member right side up, but not sure if everything-bolts, axle tubes, etc would line up then. Quote:
![]() The perches and u-bolts are cheap enough, do it right.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 02-23-2011 at 11:50 AM. |
| Bookmarks |
