Old 02-19-2011, 07:09 PM   #1
scherpich
Don't get mad...
Now I know a lot of you do not approve of the electric fuel pump, but I have installed one in my 67 C10. Does anyone have a pic of the fuse panel and which points would be good to connect it to? I don't want it to flood the engine before I start it.
scherpich is offline   Reply With Quote
Old 02-19-2011, 07:12 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Don't get mad...
Are you running a fuel pressure regulator with the electric fuel pump? I have heard Edelbrock carbs need them so the pump does not flood the engine.
You could hook it up to the unfused ignition position on the fuse panel.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-19-2011, 07:15 PM   #3
scherpich
yes, I did a little research and got a regulator before I bought it- I also put a gauge in the line so I can tune it to the right pressure. I also have an edelbrock, how much psi should I let flow?
Old 02-19-2011, 07:33 PM   #4
vectorit
What?
vectorit's Avatar
IMO there is nothing wrong with using an E pump, in fact my burb ran with one for most of it's life.
Kinda miss that power up hum that it made while it primed itself.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-19-2011, 07:59 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
5 psi should be fine for an eddie.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 02-19-2011, 09:06 PM   #6
Beat68CST
Beat68CST's Avatar
The vette we just sold always sat at about 10PSI
Then again, it was a roller 440 big block with a 930 Holley on it that made about ~750hp.
Loved watchin it jump when I'd smack the throttle...
Beat68CST is offline   Reply With Quote
Old 02-19-2011, 09:10 PM   #7
68anniversary
I would think using one of the "Ign unfused" slots in the fuse box so it turns off and on with the key. I would then run an inline fuse in the power wire feeding the pump.
68anniversary is offline   Reply With Quote
Old 02-19-2011, 10:51 PM   #8
helldiablo
agree with 68anniversary.. x1
helldiablo is offline   Reply With Quote
Old 02-19-2011, 11:22 PM   #9
truckster
truckster's Avatar
I used to run one off of the "run" position on the solenoid.
truckster is offline   Reply With Quote
Old 02-19-2011, 11:40 PM   #10
Jerry Jones
Happy Camper
Jerry Jones's Avatar
I had one on a 468 BBC with a 1050 on my boat... it was a big toilet... hit the throttle and FLUSH... gas down the hole.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
