02-19-2011, 11:20 PM | #1 |
Windshield molding issue
I had a local company install a new front windshield in 68 yesterday. In the top corners on the inside the molding buckled (looks like a piece of bacon). The installer really worked on it and said let it sit in the sun for a couple days and if it doesnt get better to bring it into his shop and they would see what they could do.
Has anyone had this problem before? Any help would be appriciated.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
02-19-2011, 11:37 PM | #2 |
Re: Windshield molding issue
I had an old school professional glass guy do mine and had the same problem.....only on one side though....The arizona heat helped a little but it never did get perfect.....couldnt find a solution at the time....Learned to live with it but it always did bug me!
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
02-19-2011, 11:48 PM | #3 |
Thats what I thought, may have to live with it. If I recall the original had a little gap in the upper corners. Thanks for the post.
02-19-2011, 11:52 PM | #4 | |
What?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
02-20-2011, 12:16 AM | #5 |
Member #1049
I have also gone through the same issues over the years with the trucks I have built and have tried many different manufactures windshield rubbers.. Some are horrible and really "bacon up" on the corners, some not so bad..
I have found that "Prescision replacement parts" gaskets are simply the better fitting and easier to install than all the rest.. its all I will use! Part numbers are: WCR 685 (accepts deep trim lip). WCR 685A (Accepts shallow trim lip). WBL 685 (for no chrome trim). |
02-20-2011, 12:43 AM | #6 |
My 69 did the same thing, I left it alone for a couple months with no improvement, I finally ended up using a little super glue, its been perfect ever since.
02-20-2011, 10:08 AM | #7 |
Thanks for the tip may need to give it a try!!
02-20-2011, 01:20 PM | #8 |
Old Skool Club
Deep vs shallow lip? Is that a year model thing? I asked because I have new rubber and new stainless trim for the windshield and back glass. I assume I bought correctly, but am not to the installation phase, so not too late to correct.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-20-2011, 02:11 PM | #9 | |
i am having trouble finding a company that has the shallow trim gasket locally. many glass people have told me in the last week that percision gaskets are the only way to go and fit very nice in the 67-72 trucks.
71 gme Sierra Grande lwb. 68 Rambler American 2 door 75 jeep cj5 |
02-20-2011, 02:29 PM | #10 |
The trim is different for 71-72 vs 67-70, as are the gaskets- but you can use 67-70 gasket and trim on 71-72- reason for this is that the 67-70 is much easier to install! The 71-72 is hard to use in best conditions. You must be sure that the trim 67-70 (deep groove) matches your gasket 67-70 (deep groove). The 71-72 gasket is a shallow groove trim that needs shallow groove gasket you can not mix and match, but for easy of install the 67-70 stuff is much easier!
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
02-21-2011, 10:22 AM | #11 |
Once installed is there a noticeable difference between the sallow and deep?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-21-2011, 10:56 AM | #12 |
I only use Soffseal in my personal rides and it lays down in the corners.
02-21-2011, 09:25 PM | #13 |
There is no visual difference installed in shallow vs deep. Only difference is ease of installation.
12-22-2014, 09:31 PM | #14 |
so glad to have this forum. Thanks 71 Super!
12-22-2014, 09:45 PM | #15 |
All about them K’s
The shallow groove trim is more likely to not stay in according to the research I've done for my cheyenne. ive got no firsthand experience but have read a few threads where the trim didn't want to stay In place very well with the later shallow design. Everyone seems to think the early 67-70 is by far the way to go if replacing it all.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-22-2014, 09:55 PM | #16 |
As a former glass shop owner, I'm pretty confident that the installer knows it's not going to get any better. That's just his way of walking away without fixing it. And it's not easy to fix; the installer has to pull the windshield partway out, and in a 67-72 there's a pretty good chance of breaking the glass.
12-23-2014, 09:49 AM | #17 |
I'd take a soft rubber mallet and work over the defective part a litte bit at a tim
12-23-2014, 11:35 AM | #18 |
the seal is wrinkled in mine also, the installer tried to fix it and broke the windshield. l ended up dealing with it wrinkled.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
