Old 03-16-2003, 07:38 PM   #1
1972chevy4x4
1972chevy4x4's Avatar
Found tach dash but had ??
Hello,
I have found a tach dash with a choke hole on right side(came out of 1 1/2 ton ), and I do not want the choke hole to remain. Is it as simple as putting a new bezel on to eliminate the hole or is something else involved? Thanks for the info Dan
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 03-16-2003, 07:42 PM   #2
Xzavior240
Xzavior240's Avatar
if all the guages line up you should be able to put a new piece in front of the guages that doesnt have the choke hole. as long as the holes are there for lights and such
71 chevy C10 LWB 2WD runs and everything
79 chevy 1/2 ton Big Ten silverado gonna part it out since it left me walking.
69 f100 real good shape with lots of go go juice
89 plymouth reliant (daily driver)
86 thunderbird sitting in the weeds almost covered (anyone need parts?)
WWW.xschunkofthenet.freeservers.com
nothing there I promise
" tell me I'm a sinner I got news for you. I spoke to god this morning and he dont like you" OZZY
Xzavior240 is offline   Reply With Quote
Old 03-16-2003, 07:43 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Dash ... with tach!!!
Thats all there is to it. Change the front bezel and your ready to go. It did have the printed circuit also I assume, and wires. It's a stand alone hook up it has nothing to do with the dash harness.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-16-2003, 07:45 PM   #4
1972chevy4x4
yeah everything is there and works just didn't want to see the remnants of a larger truck in my dash. Thanks for the info I will get it pulled tomorrow. Dan
Old 03-16-2003, 07:51 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Dash
If you check out my signatures you will see my dash. It is about 4 different dashes put together as one.
Everything is the same in all of these trucks except for the holes that some had or not the dashes inter change with each other.
If you are in the junk yards I would be looking for a clock to fit in the lower right hand hole out of a 78-80's model truck. They aren't that hard to put in.
Old 03-16-2003, 08:47 PM   #6
Rod
Change the bezel and the gas guage to a 1/2 ton model and your all set.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
