Old 02-20-2011, 02:32 PM   #1
JAG66
87 SWB lowering advice
Just picked up a one owner, low mile, garage kept, stock 87 black Silverado SWB. It sits like an old farmers truck. I'm researching lowering options. This will be a daily driver. The most I've ever lowered a square body is 2/4 with spindles, shackles/hangers/leaf spring removal. Want lower than 2/4 this time. Truck will remain stock body, mouldings, emblems, interior, etc.
Here's my want's:
To run stock tires and wheels (with option to run 18's? in the future) if 18's offer good tire selection.
No notching frame or bed supports. Don't want to compromise trucks originality.
Want to close up wheel well opening, but keep nice ride since daily driver.
I like drop spindles/drop coils/flip kit idea.
Noticed spindles come in 2", 2.5", 3" drops. Advice?
Thinking 3/5, 4/6, 5/6.
How low is feasible for DD?
Best place to purchase turn-key kit?
Opinions on shorter shocks or shock extenders?
One concern I have is driveline vibration due to pinion angles. I chased this with my 2/4 drop.
Any advice on kits and pics welcome to help me decide.
Jeff
JAG66 is offline   Reply With Quote
Old 02-20-2011, 02:51 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 87 SWB lowering advice
Welcome Aboard !
May as well get this over with.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-20-2011, 03:41 PM   #3
baclay9
Your definately going to get alot of different opinions. Definately start with at least a 3/5. You could go with 3" spindles up front and a flip kit out back. Some people apparently have problems with 8" rallies rubbing the lower control arms though and have to do some trimming on them. You wouldn't have to worry about an alignment then. If you wanted to go lower after that you could always add lowering springs in the front and a drop shackle out back.
I went 5/7 on the project I am working on and I am afraid I might have went too low but time will tell. (It is just a rolling chassis now)
baclay9 is offline   Reply With Quote
Old 02-20-2011, 03:43 PM   #4
JAG66
Originally Posted by Restrorob View Post
Welcome Aboard !
Thanks for the welcome, and you're right..... pictures required.
Old 02-20-2011, 03:52 PM   #5
JAG66
Here's a pic of my stock 78 454 SWB I lowered 2/4 with spindles/shackles/hangers. I want the same stock look on this 87, but a little lower. Maybe 3/5 or 4/6.
Old 02-20-2011, 04:25 PM   #6
87oldie
87oldie's Avatar
I THINK the lowest you can go in back without a notch is 5'" but im not 100% sure.
87oldie is offline   Reply With Quote
Old 02-20-2011, 04:26 PM   #7
thebabybrahma
hey JAG66, what size tires are on the '78? are you running 8" ralleys all the way around?
'85 C-10, with 93 LT-1 & 4L60
1985 GMC, lookin' for its big block motor - SOLD
'72 Chevy C-10 Cheyenne-SOLD
thebabybrahma is offline   Reply With Quote
Old 02-20-2011, 04:52 PM   #8
jasonroman
jasonroman's Avatar
i went with a 5-7 kit. on my my 85.
no issues thus far with lca. runs good. no issues going over bumps or tracks etc. i personally think if you do a 2-3 2-4 3-5 etc, you might end up wanting more. so i went ahead a got a 5-7 kit. to not have to do the same thing a couple times. i have 8 inch ralleys. and so far no issues.
trucks look good stock. and great lowered in my opinion.
good luck with truck either way.
jasonroman is offline   Reply With Quote
Old 02-20-2011, 05:18 PM   #9
mooseknuckles
mooseknuckles's Avatar
I agree ^^ nice truck btw.
mooseknuckles is offline   Reply With Quote
Old 02-20-2011, 05:32 PM   #10
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Your truck looks like it just rolled out of the showroom!!! Great find!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-20-2011, 05:44 PM   #11
JAG66
BFG's 255/70/15 on stock 8" ralleys on both trucks.
Old 02-20-2011, 05:50 PM   #12
JAG66
Others? Is 5" my max rear drop without a frame notch? I don't mind removing the bump stop, but will not cut the frame.
Any pictures of stock trucks with a 3/5? How would 4/5 look? Too "raked?"
I only want to go into the front once. I can tweak the rear to taste.
Old 02-20-2011, 05:59 PM   #13
3r!c84
Badass
3r!c84's Avatar
gotta ditch the spare tire holder under the bed too. and do a 4/5 drop 3inch spindle half a coil cut in the stock spring (1inch) 5inch flip kit out back
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-20-2011, 06:18 PM   #14
mooseknuckles
I fliped mine dropped it 5-6", no notch, just removed bump stop, no probs!
Old 02-20-2011, 06:21 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Do a 3/5 now and go 5/7 when you get the 18's. Don't be afraid to notch the frame. It's only metal.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-20-2011, 07:49 PM   #16
chevymotocross
chevymotocross's Avatar
4/6 on my 87 and I love it!
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-20-2011, 07:58 PM   #17
boatpuller
boatpuller's Avatar
nice truck....a 4,6 is a good all around choice without too many clearance worries.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 02-20-2011, 08:02 PM   #18
monte0185
monte0185's Avatar
I did 3/5 on mine with spindles and flip kit. I am still going to cut half a coil and see how that looks. Might go a whole coil and make it a 5/5 drop. Rear 5" drop definatley has to loose the bump stop but no notch needed.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 02-20-2011, 08:12 PM   #19
chevymotocross
That's what I was worrying about with a 3/5.... dragging butt nose high. Even with my 4/6, you can see the front has more gap than the rear but that may be because of the small 235/60 on the front.
Awesome truck either way and cutting the coils should put it where it should be.
Old 02-20-2011, 08:18 PM   #20
JAG66
What kit did you use? DJM, Bell Tech?
Old 02-20-2011, 08:41 PM   #21
monte0185
monte0185's Avatar
I used DJM. I also have 18's on the front and 20's on the back so thats another reason for the gap difference. I was looking more for the slightly raked look than a leveled look which is what i have now.
Old 02-20-2011, 09:58 PM   #22
Chlsnk
Chlsnk's Avatar
Amazing truck!
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 02-20-2011, 10:58 PM   #23
JAG66
I guess if I go with a 4" front drop, I obtain 3" spindles and 1" coils?
Old 02-20-2011, 10:59 PM   #24
3r!c84
Badass
3r!c84's Avatar
right cut half of the stock coil = 1inch of drop
-00 Saturn 5spd
1/4:13:90
Old 02-20-2011, 11:17 PM   #25
muthstryker
muthstryker's Avatar
There was a very nice write up in sport truck mag that was a black square, they did a 5/5 drop with 20s and larger tires, it looked really nice. I will see if I can find the link for you.
muthstryker is offline   Reply With Quote
