Old 02-20-2011, 02:40 PM   #1
Toxic Redline
Toxic Redline's Avatar
Question Side Fuel tank/Body lift
Ok so my truck had a 2 inch body lift when i got it, and that lets the side fuel tank hang down below the body and i hate that! Anybody moved the tank up? is that possible? or should i look into moving it between the frame rails in the back??
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-20-2011, 10:01 PM   #2
Toxic Redline
Re: Side Fuel tank/Body lift
Screw it I'll just put one in the rear between the rails i got on in the rolled burb that will work nicely
68 c20 dump bed
Old 02-21-2011, 12:04 AM   #3
blackout
blackout's Avatar
good choice i just finished installing my rear tank with electric fuel pump
blackout is offline   Reply With Quote
Old 02-21-2011, 12:09 AM   #4
Toxic Redline
was it really all that difficult? if i have all the stuff from my suburban
68 c20 dump bed
Old 02-21-2011, 12:21 AM   #5
blackout
blackout's Avatar
if you have a dremel and drills and tools like that no .. just take the bed off leave the bumper on or put something on the frame to keep it square when you remove the cross members on the pickup
you could just use the old crossmember and slide them in the right positions. I had to to relocate the rear brake bracket for it to.
those rivets were a real PITA though
heres how i mounted mine
Old 02-21-2011, 12:53 AM   #6
Toxic Redline
You wouldn't happen to have a build thred on that would you?
68 c20 dump bed
Old 02-21-2011, 01:02 AM   #7
blackout
blackout's Avatar
as a matter of fact i do not as detailed tho sorry ill add some more info to it
http://67-72chevytrucks.com/vboard/s...d.php?t=434087
