Where's my beer?
lug nut frozen to wheel stud
I was trying to take my LF wheel off, and the last lug nut is spinning, stud and all. I assume I have to cut the stud off somehow, right? I don't have a torch, so a hacksaw might be my only option. Any suggestions? Once I get it off, do ya'll think replacing the stud will take care of it?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Dave's not here, man
Re: lug nut frozen to wheel stud
I think a new stud and you'll be good to go. The little splines that hold it in place likely gave up the ghost. Is it drum or disc?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-20-2011 at 03:28 PM. |
Try using a cold chisle and splitting the nut in half.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
splitting the nut would be the best idea IMHO, im pretty sure they have special tools for that dont they???
1969 Chevy c20(Miss Hackjob) |
if you can get a cut off wheel in there that might work too.. No matter how you look at its not a fun job, but with alitte effort it will get done..
if the rim and tire are still on there the easy way is to take hold of the tire and pull forcefully to snap the stud// we used to do that when we had a wheel lock on and no key
Where's my beer?
Don't have a cut off wheel, but might get one now. I do have a compressor, and the lug nut is not tight to the wheel, so I think there is room to get a cutoff wheel behind the lug nut. It has drums, btw.
You could pull the bearing assembly and take off the drum and hub. It might be easier to get at it from the backside.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-20-2011 at 03:32 PM. |
its all about the +6 inches
thats how I would do it, remove the hub/drum assembly, and cut the head of the stud.
Moderator
![]() Join Date: May 2007
x 2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
You could drill the center out of the stud to weaken it and then break it off. It may be tricky as you will likely have to hold the nut with a plier to keep it all from spinning, but it might work. You will probably need to drill most of the center out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 02-20-2011 at 03:41 PM. |
Big Red - Now its a SWB!
That was my thought too. All of the others are good suggestions too.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#13 |
I am a Referee of life.
I think the pull it and grind the head off is the better way.Drilling it might cause more damage to the hole the stud needs to seat into.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 |
the boat guy
reminds me of a thread on some honda form. Poor kid cut his custom wheel to pieces getting the last lugnut off.
#15 |
![]() Join Date: Dec 2007
Dremel tool works good in tight places as well. If a nut splitter will fit, that might be an option.
Remember, anti-seize compound is your friend! |
#16 |
Where's my beer?
Thanks guys, bought a cut off wheel and got it off. Now I need to take the drum off tomorrow and replace the stud. Dumb question, should the drum just come off, or does the "hat" under the spindle nut need to come off to remove the drum?
#17 | |
![]() If you can get to the axle nut then taking the assembly off and drilling out the back would be the easiest.
1953 Chevy 6400 Truck - 2 Ton Pickup Project - 5.9 CTD, 6 Sp Allison, Air Ride, 22.5 Wheels 1952 Chevy 6400 Truck - Looking for a direction in life |
