![]() Join Date: Mar 2005
Maximum wheel width w/stock rear end
What's that maximum wheel width you can run in the rear of the 60-66 trucks with a stock width rear end? This would be on a lowered truck with the tires tucked in the wheel wells.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Re: Maximum wheel width w/stock rear end
I also would like this information.
10 inch with untouched fender wells, still have to roll the outside fender lip for clearance.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Do you remember what the backspace was? On all my later trucks (73-87) it had to be around 4.25-4.50 on the backspace to fit, and that really narrowed down my wheel choices.
If I`m not mistaken that was the backspacing,,
#6 | |
I'm running 10's on my 64 w/5.50"bs & mini-tubs because it's going to be loooooooooooooooow. Any less back spacing would interfere w/the exterior bedside sheet metal. If the bed floor is cut & tubs stretched, 14" wide wheels will fit w/the right back spacing & some slight modding.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-20-2011 at 09:15 PM. |
Resistance is Futile
On my SB with 5.25''bs I had to widen the rear tubs. Somewhere in the high 4''+ area of backspace is where you will hit I believe. My 'burb has a '71-72 rear axle and I was able to get a 295/50 on a truck Rally wheel in there. Trimmed the lip completely off.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
![]() Join Date: Jan 2011
The rears on my truck are 9.5 width. (stamped on the rim) there 16.5's and the tires are 31 x 10.5 and they fit with a heavy camper on the back. So the ratio might be simular. Squatted and full fenderwell . Just another data point to look at.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
I have a 9" rim with 0 backspace and a 255 60 17 tire and it fits very nice. There is about 1" on either side of the tire. I could probably put a 275 on there but it would be tight. There's also about 1" of fender lip I could cut off of my fleet bed if I want.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
There simply is no substitute for measuring your specific vehicle.
Jack up the truck under the rear axle, or under the front lower a-arm, remove the wheel/tire ass'y., get your straight edge and tape measure out, and start measuring. Deep breath... ![]() ![]() You really can't buy tires and wheel based solely on "What some other guy did", even if your truck is bone stock. If you're buying Cragars than you obviously don't have a stock set-up (none of these trucks were sold with 5 lug wheels) and other peoples advice therefore should be merely the starting point of your search. From the factory these trucks had dimensional variations, let alone tweaking and parts interchanging after nearly 50 years of use and abuse. Not trying to be a smart a$$, but in my experience this is one of those times where you need to follow the good old adage of "If you want something done right, do it yourself". |
Exactly. Everything everyone else wrote is to give you an idea of what is possible. There's no substitute for a tape measure. Heed lakeroadster's advice.
#12 | ||
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 02-20-2011 at 11:44 PM. |
#13 |
Or the simple way to measure:
http://www.percyshp.com/WheelRite.html This could come in handy also.... http://www.tirerack.com/accessories/detail.jsp?ID=52 |
